IPB
> Notice!
> New Feature: show tag update options on the main window, for at a glance overview and adjusting
Sabio
post May 20 2008, 09:07
Post #1
Member
Group: Full Members
Mp3tag Version: 2.46c
It would be very helpful if options whether to read/write/remove ID3v1/ID3v2/APE were available on the main window.
Right now I need to go to Options every time to make sure that I will not kill some useful tags and will write all the necessary information.
Tag panel has plenty of space - so the options could be shown there. As for UI solution, that could be done like on this screenshot of MP3-Check:
(with checkboxes instead of radio-buttons)
Or on the toolbar, somehow.
P.S. Prompt before removing tags with Ctrl+R would very helpful as well - sometimes I find myself pressing Ctrl+R to refresh the view sad.gif
Go to the top of the page
+Quote Post
dano
post May 20 2008, 09:14
Post #2
Moderator
Group: Moderators
Mp3tag Version: 2.55a
"Prompt before removing tags" is already possible at Options > Messages
+Quote Post
Sabio
post May 20 2008, 16:02
Post #3
Member
Group: Full Members
Sorry, I might have been wrong indeed.
I was checking against 2.39 version I use on this PC (since I cannot install 2.40 on W2K)
+Quote Post
Sabio
post Apr 7 2009, 12:21
Post #4
Member
Group: Full Members
Could you please make that remove tag confirmation dialog shows which particular tag types are going to be removed?
So instead of just "Do you really want to remove the tags of the selected files?" it would say something like "Do you really want to remove ID3v1, APEv2 tags of the selected files?"
As a final confirmation that tag removal options are set correctly.
(I'm still in favour of solution to make them easily visible and changeable on the main window)
This post has been edited by Sabio: Apr 7 2009, 12:23
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 25th May 2013 - 13:41
