Sep 8 2011, 06:56
Post
#1
Member Group: Members Posts: 2 Joined: 29-July 11 Member No.: 14969 Mp3tag Version: 2.49 |
I want to remove a part of the file name per the below example:
file name is "anita baker - rapture.mp3" or "john legend - ordinary people.mp3" I want a script to remove everything up to and including the "-" in all file names so all the file names just have a space before the artist name (inserting track number with another macro). I can't find out to do this because there are no certain number of characters. I could do replace for each artist, but I have to type in each artist's name. Is there an easier way? Please email response to "raybharrell@gmail.com" |
Sep 8 2011, 07:31
Post
#2
![]() Member Group: Full Members Posts: 416 Joined: 3-December 10 From: Ireland Member No.: 13334 Mp3tag Version: 2.55a |
Please email response to "raybharrell@gmail.com" I don't think you should put this in any future posts. This is a forum after all and other people may need this info. To change anita baker - rapture.mp3 To rapture.mp3 Action type: Replace with regular expression Field: _FILENAME Regular expression: ^(.+-\s)(.+) Replace matches with: $2 [ ] case-sensitive comparison How it works I've attached a screen shot of the regexp. On the top half you'll see "^" which anchors it to the very start of the text and "()" with stuff inbetween those. Basically they capture whatevers inside them. So the return is $2 which in-cases what you need. But for example you COULD say $1 which would return "anita baker - " instead of "rapture.mp3" -------------------- I ♥ singing Dubstep ♪♫WOOB WOOB WOOB WOOB UBB OHMOMOMO DROP WOOOOOOB WOOB WOOB WOOB WUB WUB WUB WUB WUB WUB WUB WUB MOMOMO WOOB WOOB♫♪
Sep 8 2011, 21:31
Post
#3
![]() Member Group: Full Members Posts: 775 Joined: 18-April 05 Member No.: 1742 Mp3tag Version: 2.55a |
I want to remove a part of the file name per the below example: file name is "anita baker - rapture.mp3" or "john legend - ordinary people.mp3" I want a script to remove everything up to and including the "-" in all file names so all the file names just have a space before the artist name (inserting track number with another macro). I take it the second part is the song title? If you already have the title in the TITLE field, then all you need to do is rename the file using that field. Action type: Format value Field: _FILENAME Format string: %title% To include the track number, use Action type: Format value Field: _FILENAME Format string: $num(%track%,2) %title% |
Sep 9 2011, 07:15
Post
#4
![]() Member Group: Full Members Posts: 4129 Joined: 26-May 06 From: Wuppertal, Germany, Planet Earth Member No.: 3194 Mp3tag Version: 2.54 |
I want to remove a part of the file name per the below example: file name is "anita baker - rapture.mp3" or "john legend - ordinary people.mp3" I want a script to remove everything up to and including the "-" in all file names so all the file names just have a space before the artist name (inserting track number with another macro). I can't find out to do this because there are no certain number of characters. I could do replace for each artist, but I have to type in each artist's name. Is there an easier way? ... 1. Be aware of, that a file name, which starts with a space character, might be not allowed by the underlying filesystem. For example, Windows Explorer automatically removes leading space characters from the filename, when trying to rename a file to get leading space characters. 2. Action: Format value Field: _FILENAME Formatstring: %TRACK% $right(%_filename%,$strstr($reverse(%_filename%),'- ')) From: TRACK = 1 FILENAME = john legend - ordinary people To: FILENAME = 1 - ordinary people ... or ... Action: Format value Field: _FILENAME Formatstring: %TRACK%$right(%_filename%,$strstr($reverse(%_filename%),' - ')) From: TRACK = 1 FILENAME = john legend - ordinary people To: FILENAME = 1 ordinary people DD.20110909.0817.CEST Edit.20120621.1705.CEST This post has been edited by DetlevD: Jun 21 2012, 16:05 -------------------- * Beyond that, don't ask, when you don't know what to do with the answer. *
♥ home is where the heart is ♥ |
Lo-Fi Version | Time is now: 25th May 2013 - 16:34 |
