Jun 23 2012, 14:40
Post
#1
Member Group: Full Members Posts: 103 Joined: 9-February 10 Member No.: 11832 Mp3tag Version: 2.45b |
How do I write a script to Cap letters after quotation.
Ex: Let 'em Dance to read - Let 'Em Dance Now You Got 'em to read - Now You Got 'Em Thanks |
Jun 23 2012, 19:09
Post
#2
![]() Member Group: Full Members Posts: 3228 Joined: 9-December 09 From: Norddeutschland / Northern Germany Member No.: 11458 Mp3tag Version: 2.55a |
How do I write a script to Cap letters after quotation. Ex: Let 'em Dance to read - Let 'Em Dance Now You Got 'em to read - Now You Got 'Em Thanks A script? Or an action? If so: create an action of the type case conversion for the field you need (e.g. TITLE). Add the apostrophe to the characters that show the word boundaries. -------------------- 42 - wie war die Frage / what was the question / comment était la question
Jun 23 2012, 19:12
Post
#3
![]() Member Group: Full Members Posts: 4130 Joined: 26-May 06 From: Wuppertal, Germany, Planet Earth Member No.: 3194 Mp3tag Version: 2.54 |
How do I write a script to Cap letters after quotation. Ex: Let 'em Dance to read - Let 'Em Dance Now You Got 'em to read - Now You Got 'Em Thanks Convert | Tag - Tag | ALT+5 Select format string Field: TITLE Format string: $caps(%TITLE%,'' ) ... or ... $caps(%TITLE%,$char(39)$char(32)) Preview From: Let 'em Read to learn To: Let 'Em Read To Learn ... or even better ... Convert | Tag - Tag | ALT+5 Select format string Field: TITLE Format string: $regexp(%TITLE%,'(\s''''.)','\U$1') Preview From: Let 'em read to learn (Let's do it again) To: Let 'Em read to learn (Let's do it again) ... or use an action ... Begin Action Group Test_2012#20120623.ApoUpper Action #1 Actiontype 4: Replace with regular expression Field ______________: TITLE Regular expression _: (\s'.) Replace matches with: \U$1 [_] Case sensitive comparison End Action Group Test_2012#20120623.ApoUpper (1 Action) See also .... http://forums.mp3tag.de/index.php?showtopic=14390 DD.20120623.2013.CEST Edit. DD.20120627.0630.CEST This post has been edited by DetlevD: Jun 27 2012, 08:13 -------------------- * Beyond that, don't ask, when you don't know what to do with the answer. *
♥ home is where the heart is ♥ |
Jun 24 2012, 14:39
Post
#4
Jun 26 2012, 21:15
Post
#5
![]() Member Group: Full Members Posts: 424 Joined: 3-December 10 From: Ireland Member No.: 13334 Mp3tag Version: 2.55a |
How do I write a script to Cap letters after quotation. Ex: Let 'em Dance to read - Let 'Em Dance Now You Got 'em to read - Now You Got 'Em Thanks To make sure you don't change files with 'let's' or 'They've' for example. From: Let 'em Dance to read (Let's Not Change this) To: Let 'Em Dance To Read (let'S Not Change this) FILTER [F3] out the files first with the following examples: %title% MATCHES \s This will make ensure you only filter out 'Let 'Em Dance To Read' and NOT 'Let's Not Change this' %title% HAS ' Titles with all ' THEN USE: Begin Action Group _Script Test#TEST Action #1 Actiontype 4: Replace with regular expression Field ______________: TITLE Regular expression _: (\s+)'(.?) Replace matches with: $1'$upper($2) [_] Case sensitive comparison End Action Group _Script Test#TEST (1 Action) This will only effect anything with a space in front of the '. -------------------- ▶✚♬ ═ ♡
Lo-Fi Version | Time is now: 20th June 2013 - 04:58 |
