Aug 29 2009, 22:23
Post
#1
Member Group: Full Members Posts: 5 Joined: 29-August 09 Member No.: 10821 Mp3tag Version: 2.43 |
Hi, if anyone could help me with this little coding problem Id be extremly greatful...
When exporting to nfo Id like the track length info (%_length%) to be alligned vertically. Ive been looking into how Dano does this in his nfo code, but i cant figure it out. Dano's script lacks artist info (there is only "track no. - track title - track length"). I really need artist (%artist%) to be included since I have alot of VA albums. This is the standard code i use: (Currently I always need to manually allign all the %_length% after export...) CODE $loop(%_path%)%track%. %artist% - %title% %_length% $loopend() This is how i want it to look: CODE Tracklisting: Time: 01. Artist A - Track A 01:00 02. Artist B - Track B 02:37 03. Artist C - Track C 05:26 04. Artist D - Track D 05:31 05. Artist E - Track E 02:58 06. Artist F - Track F 07:31 07. Artist G - Track G 03:30 08. Artist H - Track H 07:40 Total: 00:42:31 Thanks for any help! (sorry for my lack of knowledge how to do this) |
Aug 29 2009, 23:03
Post
#2
Member Group: Full Members Posts: 199 Joined: 30-January 09 Member No.: 8442 Mp3tag Version: 2.48c |
Try this:
QUELLTEXT $loop(%_path%)%track%. %artist% - %title%$repeat( ,$sub(60,$len(%artist% - %title%)))%_length% $loopend() |
Aug 29 2009, 23:18
Post
#3
Ah! Thx a million!
Aug 30 2009, 02:04
Post
#4
Sorry if Im pushing my luck here (please forgive me)...
but is it possible to add a line break when the number of character in %artist% plus %title% reaches the defined placement of %_length%? So that the rest of the track title continues on the next line? (On second thought that probably would be difficult, both because it would need the the correct spacing on next line as well as track title needs to break at a whole word not just the number of characters that reaches the limit...) Is it possible? :S CODE Tracklisting: Time:
01. Artist A - Track A 01:00 02. Artist B - Track B with a Really Really Really 02:37 Long Track Name 03. Artist C - Track C 05:26 |
Aug 30 2009, 08:43
Post
#5
v1:
QUELLTEXT $loop(%_path%)$num(%track%,2). $left(%artist% - %title%,60) $repeat( ,$sub(60,$len($left(%artist% - %title%,60)))) $mid(%artist% - %title%,61,60) $repeat( ,$sub(60,$len($mid(%artist% - %title%,61,60)))) $loopend() v2 (No empty lines): QUELLTEXT $loop(%_path%)$loop(%_path%)$num(%track%,2). $iflonger(%artist% - %title%,60,$left(%artist% - %title%,60) $repeat( ,$sub(60,$len($left(%artist% - %title%,60))))
$mid(%artist% - %title%,61,60) $repeat( ,$sub(60,$len($mid(%artist% - %title%,61,60)))),$left(%artist% - %title%,60) $repeat( ,$sub(60,$len($left(%artist% - %title%,60))))) $loopend() |
Aug 30 2009, 11:45
Post
#6
Wow thank you
One problem though, i get non-matching no. of loop/loopends on both versions... I just cannot get my head around how to close them. Final help? |
Aug 30 2009, 13:40
Post
#7
Sorry. Now it should work.
v1: QUELLTEXT $loop(%_path%)$num(%track%,2). $left(%artist% - %title%,60) $repeat( ,$sub(60,$len($left(%artist% - %title%,60))))%_length% $mid(%artist% - %title%,61,60) $repeat( ,$sub(60,$len($mid(%artist% - %title%,61,60)))) $loopend() v2 (No empty lines): QUELLTEXT $loop(%_path%)$num(%track%,2). $iflonger(%artist% - %title%,60,$left(%artist% - %title%,60) $repeat( ,$sub(60,$len($left(%artist% - %title%,60))))%_length% $mid(%artist% - %title%,61,60) $repeat( ,$sub(60,$len($mid(%artist% - %title%,61,60)))),$left(%artist% - %title%,60) $repeat( ,$sub(60,$len($left(%artist% - %title%,60))))%_length%) $loopend() |
Aug 30 2009, 14:19
Post
#8
Perfect!!! Thank you so much newser!
Nov 23 2010, 00:00
Post
#9
Member Group: Members Posts: 1 Joined: 22-November 10 Member No.: 13273 Mp3tag Version: v2.47 |
Thank you so much |
Lo-Fi Version | Time is now: 18th June 2013 - 23:25 |
