IPB
> Notice!
> [Feature Request] Folder name as album tag default
a843525@uggsrock...
post Nov 8 2009, 04:56
Post #1
Member
Group: Full Members
Mp3tag Version: 2.44h
First, thanks for the wonderful software. I've been using it for a very long time.
Under Tag Panel's default values, we are presented with a scroll-down list of 3 choices: <blank>, <keep>, and <enter>.
Very often I name the file folders on my PC according to the album names. I suspect many people do the same. I wonder if you could add an additional choice of <folder> to the list, so that the folder name is used as one of the selectable values for the album tag.
After implementation, the scroll list would look something like:
<blank>
<keep>
<folder>
<enter>
For instance, if I have a list of mp3s inside this folder on my pc: c:\music\donald duck songs\
I could simply use <folder> as the tag for 'album', and 'donald duck songs' would be used as tag for the mp3s' album.
Go to the top of the page
+Quote Post
Florian
post Nov 8 2009, 10:02
Post #2
Developer
Group: Admin
Mp3tag Version: 2.55a
This is what the converter mt_ftt.png Filename - Tag is used for: just import the folder name to the album field by using a format string like
CODE
%album%\%dummy%
Kind regards,
Florian
+Quote Post
a843525@uggsrock...
post Nov 8 2009, 12:43
Post #3
Member
Group: Full Members
Thanks! I didn't know that the filename-to-tag converter could be used to capture the folder name as well.
Wow, this opens a whole new world. I could load many folders, or subfolders, and easily convert them all at once!
Thanks again.
+Quote Post
Goutam
post Oct 2 2011, 15:39
Post #4
Member
Group: Members
Mp3tag Version: 2.49
Thanks, that helped me too.
But suppose the song is in a folder...
"H:\Entertainment\Songs\English\Avril Lavigne\The Best Damn Thing"
and I want the album tag to be like 'Avril Lavigne - The Best Damn Thing'
what should be the syntax then?
+Quote Post
ohrenkino
post Oct 2 2011, 18:27
Post #5
Member
Group: Full Members
ZITAT(Goutam @ Oct 2 2011, 16:39) *
As the converter could not import a variable (like %album%) and a literal at the same time (which ist the hyphen in your example) you are stuck with a "format tag field" action.
If you can do without the hyphen, though, then the syntax would be:
%album%\%album%
But you should import artist and album separately with the mask
%artist%\%album%
and then format the tag field album:
Format tag field ALBUM
Format String: %artist% - %album%
42 - wie war die Frage / what was the question / comment était la question
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 21st May 2013 - 16:26
