IPB
> Notice!
> Import Tags from file name, split from 1204
bashdabash
post Nov 12 2009, 15:09
Post #1
Member
Group: Members
Mp3tag Version: 2.44
Hi, new to this forum, can't find where to post my question so I thought best to add to this one.
I am trying without success to get this:
"15 You're Not Gangsta Like Ross Whiteman D12 featuring King Gordy.mp3"
To be:
Track 15
Title Your Not Gangsta Like Ross Whiteman
Artist D12 featuring King Gordy
or
Artist D12
Featuring King Gordy
or
Group/Band
D12
(Note - bold and italics used for illustration purposes only, "bold text" represents field names and "italic texts" represents field data.)
Go to the top of the page
+Quote Post
DetlevD
post Nov 12 2009, 18:01
Post #2
Member
Group: Full Members
Mp3tag Version: 2.54
QUOTE (bashdabash @ Nov 12 2009, 15:09) *
...I am trying without success to get this:
To be:
Track 15
or
Artist D12
or
Group/Band
D12
Featuring King Gordy....
The filename is not so well formed to allow Mp3tag to guess how to fill the fitting tag fields.
As a first step you may reformat the filename by a regular expression like you find it in the following proposal and then let Mp3tag guess the values.
Action #1
Actiontype 7: Import tag fields (guess values)
Source format: $regexp(%_filename%,'^(\d+)÷(.+)÷(.+?)÷featuring÷(.+?)$','$1÷-÷$2÷-÷$3÷-÷$4')
Guessing pattern: %TRACK%÷-÷%TITLE%÷-÷%ARTIST%÷-÷%FEATURING%
Note: Replace each special ÷ character with one space character.
This is rather tricky and does not work in all cases but with filenames havin the same word structure like the example filename.
DD.20091112.1800.CET
+Quote Post
bashdabash
post Nov 12 2009, 18:43
Post #3
Member
Group: Members
QUOTE (DetlevD @ Nov 12 2009, 17:01) *
Action #1
Source format: $regexp(%_filename%,'^(\d+)÷(.+)÷(.+?)÷featuring÷(.+?) ,'$1÷-÷$2÷-÷$3÷-÷$4')
Thanks for that help, I guess it might be easier to just put some dashes in the title, I and looking through my 6000+ collection and only a couple hundred files are like this.
A quick question because I can't fine the post - How do I remove the "." from eg. "01." so it shows as "01" in the track field?
+Quote Post
Quaraxkad
post Nov 12 2009, 19:58
Post #4
Member
Group: Full Members
Mp3tag Version: 2.44h
QUOTE (bashdabash @ Nov 12 2009, 12:43) *
Where did that dot come from? There isn't one in that example filename, if you're talking about something else give an example.
This post has been edited by Quaraxkad: Nov 12 2009, 19:58
+Quote Post
bashdabash
post Nov 15 2009, 19:57
Post #5
Member
Group: Members
QUOTE (Quaraxkad @ Nov 12 2009, 18:58) *
The dot is after the track number, in my case the track number is 01. 02. 03. etc. when the track field is populated I want it to be show as 01 02 03 without the dot.
+Quote Post
Quaraxkad
post Nov 16 2009, 01:33
Post #6
Member
Group: Full Members
QUOTE (bashdabash @ Nov 15 2009, 13:57) *
Where does the track number come from though? Are you doing Filename to tag, and there's a dot in the filename? If that's the case then you just need to add a . to the formatting string after the track number. Need more more information to give a more specific answer.
If you just want to remove the . from existing TRACK fields, make a Replace action that searches the TRACK field and replace . with nothing.
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 19th May 2013 - 08:05
