Jan 21 2010, 17:16
Post
#1
![]() Member Group: Full Members Posts: 25 Joined: 1-October 05 Member No.: 2192 Mp3tag Version: 2.46d |
I'm using version 2.45a in Vista SP2, and the $validate() function is only validating the filename, not the full path. A short example:
$validate(%album%\%artist%, '_') only evaluates %artist% for invalid characters, if there are any present in %album% they just get removed. However, $validate(%album% %artist%, '_') validates everyting (album and artist) The help file cleary states: Remove invalid characters from file name/file paths so this should work for file paths too and not only for the filename right? I was using this with 2.44 and it worked ok, should I be using another syntax for validating the path AND filename? |
Jan 21 2010, 21:40
Post
#2
![]() Developer Group: Admin Posts: 7622 Joined: 12-December 01 From: Germany, Dresden Member No.: 203 Mp3tag Version: 2.55a |
If I have ARTIST=Test? and ALBUM=Test? and use $validate(%album%\%artist%,_) I get Album_\Artist_ as result.
Can you please post detailed information about the content of the tag fields and the result you're observing. Thanks! Florian -------------------- |
Jan 22 2010, 19:20
Post
#3
Hi Florian, thx for the quick reply. Here is the info you requested:
Tag-Filename code $validate($if($eql(%genre%,'Soundtrack'),'_Soundtracks\['%year%']' %album%\,%artist%\'['%year%']' %album%\)$ifgreater($right(%discnumber%,1),1,CD$left(%discnumber%,1),)\$num(%track%,2). %title%,'_') Test case Artis: "Iced Earth" Album: "The Crucible of Man: Something Wicked Part 2" Title: "Sacred Flames" Year: "2008" Track: "1" Disc: "1/1" Tag: "Flac" Result Iced Earth\[2008] The Crucible of Man Something Wicked Part 2\01. Sacred Flames.flac .... also a simple $validate(%album%\%title%, '_') has the same result regarding the validation of the album string, however if I use $validate(%album% %title%, '_') the %album% part is correctly evaluated. This post has been edited by blackspawn: Jan 29 2010, 10:40 |
Feb 21 2010, 17:24
Post
#4
Hi Florian,
I don't mean to bother you but have you any news or been able to verify this on your end? Thanks! |
Feb 21 2010, 21:18
Post
#5
Yes, it happens for colons only and will fixed with the next version. Thanks for reminding me
Kind regards, Florian -------------------- |
Feb 21 2010, 23:41
Post
#6
Feb 27 2010, 15:12
Post
#7
This is now fixed with Mp3tag v2.45c.
Lo-Fi Version | Time is now: 18th June 2013 - 06:06 |
