Mar 19 2010, 17:40
Post
#1
Member Group: Members Posts: 2 Joined: 19-March 10 Member No.: 12111 Mp3tag Version: 2.46 |
Can anybody provide an export script that creates playlists in .PLS format? My programming skill is lousy and unfortunately my car audio system does not support .m3u format. Only .pls format is supported. I did not find a way to create these files through the ordinary "create playlist" function. Thanks in advance!! |
Mar 19 2010, 19:01
Post
#2
![]() Moderator Group: Moderators Posts: 5507 Joined: 4-September 03 From: Germany Member No.: 201 Mp3tag Version: 2.55a |
CODE $filename(%_folderpath%%artist%-%album%.pls,ansi)'['playlist']'
$loop(%_filename%)File%_counter%=%_filename_rel% Title%_counter%=%title% Length%_counter%=%_length_seconds% $loopend()NumberOfEntries=%_max_counter% Version=2 -------------------- |
Mar 19 2010, 19:50
Post
#3
Exactly what i'm looking for! Thank you very much!
Lo-Fi Version | Time is now: 25th May 2013 - 20:55 |
