IPB
> Notice!
> Windows 7 and comments tag?
Lambas
post Mar 29 2010, 17:36
Post #1
Member
Group: Members
Mp3tag Version: 2.39
Hi!!!
when i write a "comments" tag via windows7 file properties
i can then see this "comment tag" to mp3tag
but if i write a "comment tag" via mp3tag then i cant see is in the windows7 file properties or windows7 explorer :/
everything else is working cool!
any help please?
Go to the top of the page
+Quote Post
ohrenkino
post Mar 30 2010, 18:35
Post #2
Member
Group: Full Members
Mp3tag Version: 2.55a
ZITAT(Lambas @ Mar 29 2010, 18:36) *
Hi!!!
You will find that none of the comments incorporated in an mp3 file and written by an mp3 tagger show up in the explorer's comment field.
I speculate that the order of tags changes once you use a decent mp3 tagger and that the explorer comment field then moves to a another place in the sequence so that the explorer does not recognize it. But this is just a wild guess.
Still: as Microsoft came later than the mp3 tags Microsoft should display and handle the comment tag correctly - which it does not.
This post has been edited by ohrenkino: Mar 30 2010, 18:35
42 - wie war die Frage / what was the question / comment était la question
+Quote Post
Lambas
post Mar 31 2010, 02:27
Post #3
Member
Group: Members
thanks very much ohrenkino!!
i quit comment and now using "album artist" for comment (i dont need album-artist anyway ... only the simple artist )
thank you
+Quote Post
ohrenkino
post Apr 1 2010, 20:06
Post #4
Member
Group: Full Members
ZITAT(Lambas @ Mar 31 2010, 03:27) *
thank you
Just if you want to still use the comment tag:
Apparently Windows considers the language settings for "comment" which have to be the same for the mp3 tag and the explorer comment field.
http://forums.mp3tag.de/index.php?showtopic=8660
shows how to adapt the mp3tag default comment language setting.
As this is a method that only works on your local machine and for one language, most tags on the other hand are the treated equally regardless of the OS language, I would prefer to use the tags (just like you did now).
BUT: as MP3tag has so many functions to manipulate even such specialities, you may want to write a little action that sets the correct language for your comments
+Quote Post
kael
post Feb 11 2011, 23:35
Post #5
Member
Group: Full Members
Mp3tag Version: 2.36
Is there a way to show a column with the language of the ID tag so you easy see which language a tracks has?
I know you can add extra colums besides the standard ones,
i.e. I added %_id3v2_character_encoding% to see the Char encoding.
But what field to use to see the language (for the comment tag)? Is this possible? Would be a great help to clean up all my mp3's.
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 21st May 2013 - 19:33
