Apr 27 2010, 01:28
Post
#1
Member Group: Members Posts: 2 Joined: 27-April 10 Member No.: 12316 Mp3tag Version: 2.46 |
First post here.
I have been using MP3tag v2.46 for a few weeks now, just using the basic features, no scripts, or anything like that. My problem is that some of the music that I have does not have the correct Album information, so I have been going through each song one by one, and looking the Album up on Amazon. I was searching here on the forums just to see if there was a way to do this in Mp3tag using scripts, when I found this topic. My question is, is there a way to automate the process of finding the correct Album using scripts in Mp3tag? Also, I do a little bit of scripting in AutoHotKey (not to be confused with the scripts in Mp3tag), and I have automated the process somewhat as described by the OP above. I can highlight text, and use Ctrl-S to look up the text in Amazon, or I can use Ctrl-G to Google the text, or Ctrl-W to do a Google site search on Wikipedia. If there is no better way to do what I need to do, I will continue along my current path. If anybody is interested, I can refine my script, and post the code for other users to try, and suggest improvements. Thanks for Mp3Tag! :-) |
Apr 27 2010, 20:19
Post
#2
Member Group: Full Members Posts: 108 Joined: 25-December 09 From: Pittsburgh PA, USA Member No.: 11538 Mp3tag Version: 2.49 |
I was searching here on the forums just to see if there was a way to do this in Mp3tag using scripts, when I found this topic. What topic? Did you leave out the link? I can refine my script, and post the code for other users to try, and suggest improvements. I use AutoHotkey quite a bit, I'd like to see your script. I like anything that can speed up the tagging process. |
Apr 28 2010, 01:26
Post
#3
I originally replied to this topic:
http://forums.mp3tag.de/index.php?showtopi...opid=46672& One of the Mods must have move my post, and started a new topic for me. I cleaned up the script a bit. Since you are familiar with AHK, I have attached 7z file with both an exe file, and a copy of the source. It works well for me, using Win7 / IE8. I haven't tested on anything else. My filenames are in [Artist] - [Title] format. The sequence that I use to find an album goes like this: 1. Click on a row to highlight the row. 2. Click again on the filename to change to edit mode (where you can enter/edit text) 3. Ctrl + Shift + A = Tag Sources > Amazon 4. If Mp3tag finds a suitable album, go with it! (Go to step1 ) 5. If not use one of the key combo below for various search types. (in order of preference) A. Ctrl + Shift + W = Search > Google Site: Wikipedia B. Ctrl + Shift + D = Search > Discography from Wikipedia C. Ctrl + Shift + G = Search > Google 6. Highlight text on search page 7. Ctrl + Shift + A = Tag Sources > Amazon And keep repeating until finished. The script will switch windows for you. I could automate it some more, by having it perform a search automatically if an album is not found by using Ctrl + Shift + A in step 3. If you have any ideas for improvement, I would like to hear them, and if You make any changes to the code, please share. Ok the upload failed. Says I can't upload a 7z file. I will work on it, If I have to I'll post a link. http://www.mediafire.com/?mz1dlcttkij This post has been edited by Morpheus: Apr 28 2010, 01:43 |
May 1 2010, 17:01
Post
#4
Well I got your script to work after a couple minor changes to this:
Sleep, 50 Click, 205 35 Sleep, 50 Click, 238, 110 It wouldn't work because the coordinates were off. That's why I try to avoid clicking by coordinates if at all possible, keystrokes are more reliable. So I changed it to: Sleep, 50 Send, {Alt}s ;Clicks Tag Sources Sleep, 50 Send, {Down 2} ;Highlights Amazon.com Sleep, 50 Send, {Enter} ;Opens the search box After that it was working well with Amazon. When I have some more time I'll test searching the other sites. I use Firefox so I might have to make a few changes for that. |
Lo-Fi Version | Time is now: 25th May 2013 - 09:53 |
