Aug 20 2010, 13:03
Post
#1
Member Group: Full Members Posts: 41 Joined: 18-August 10 Member No.: 12778 Mp3tag Version: 2.46a |
hi again i need to ask you if you can help me how can i reverse a titlename in the filename like this above
example bad-02-micahel jackson to michael jackson - bad only the file name is it possible? |
Aug 20 2010, 13:20
Post
#2
![]() Moderator Group: Moderators Posts: 5506 Joined: 4-September 03 From: Germany Member No.: 201 Mp3tag Version: 2.55a |
Use "Convert > filename - filename"
Old mask: %1-%2-%3 New mask: %3 - %1 -------------------- |
Aug 20 2010, 15:46
Post
#3
Aug 20 2010, 17:19
Post
#4
You have the filename
bad-02-michael jackson.mp3 and it should be changed to michael jackson - bad.mp3 It works. Can you show a screenshot? -------------------- |
Aug 31 2010, 10:17
Post
#5
Aug 31 2010, 10:49
Post
#6
![]() Member Group: Full Members Posts: 4129 Joined: 26-May 06 From: Wuppertal, Germany, Planet Earth Member No.: 3194 Mp3tag Version: 2.54 |
HI, HOW CAN I GET A SCREENSHOT? 1. On the keyboard press the [PrintScreen] key. This will create an image copy from the entire screen and put it to the clipboard. Alternative: Press [Alt+PrintScreen] to take a screenshot of the currently selected window. 2. Open any graphic application, which can get image content from the clipboard and can save the image to a diskfile, so get the image from the clipboard, cut the size to the important area, save the image file to disk as of filetype "png" or "jpg" to reduce storage size and upload time. If you choose the lossy "jpg" format, then use a compression factor which does not hurt the image information too much. Find out the compression respectively quality where the textual image content is still readable and the image size is reasonable small (jpg quality from 90% down to 75%). 3. Attach the image file to your forum message. See also: http://en.wikipedia.org/wiki/Screenshot DD.20100831.1157.CEST Edit.DD.20100916.0900.CEST This post has been edited by DetlevD: Sep 16 2010, 08:00 -------------------- * Beyond that, don't ask, when you don't know what to do with the answer. *
♥ home is where the heart is ♥ |
Lo-Fi Version | Time is now: 24th May 2013 - 01:35 |
