Aug 29 2010, 18:18
Post
#1
Member Group: Members Posts: 3 Joined: 29-August 10 Member No.: 12852 Mp3tag Version: 2.46a |
Is there a simple way to add another genre to a group of files regardless of the current genre. The outcome being that the files end up with 2 or more genre tags.
I'm mainly dealing with flac files. Thanks Richard |
Aug 29 2010, 19:53
Post
#2
![]() Moderator Group: Moderators Posts: 5500 Joined: 4-September 03 From: Germany Member No.: 201 Mp3tag Version: 2.55a |
Try "View > Extended Tags" or in the tag panel write genre old\\genre new
Aug 29 2010, 20:00
Post
#3
Try "View > Extended Tags" or in the tag panel write genre old\\genre new I can do that manually if I group files where "genre old" is the same for all files. I'd like to be able to do in one hit for a group of files where the original genre or "genre old" is different. Thanks Richard |
Aug 29 2010, 20:19
Post
#4
True, also Extended Tags doesn't work at all.
DetlevD had a nice idea: Add a custom tag field (i.e. ADDGENRE) to your tag panel at "Options > Tag panel" Then create an action group format value Field: GENRE Format string: $meta_sep(genre,\\)\\%addgenre% Enter your new genre in the addgenre field in the tag panel, then call the action. -------------------- |
Aug 30 2010, 07:19
Post
#5
That did exactly what I was trying to do.
Thanks for your help. Richard |
Lo-Fi Version | Time is now: 18th May 2013 - 23:35 |
