IPB
> ManiaDB, Korean Music Source w/ over 3M record
veritas
post Sep 16 2010, 01:31
Post #1
Member
Group: Full Members
Mp3tag Version: 2.45
I have tried to get this source work with mp3tag for 2days and I finally gave up. huh.gif
I am hoping any geek here could make this Korean music database work with mp3tag!!
it has over 3m record with very high quality album arts.
also, it contains worldwide music record.
here is an example of search "beatles"
(http://www.maniadb.com/search.asp?sr=PO&q=beatles&src=S&qc2=&srp=P&ql2=&srs=A&qs2=)
(http://www.maniadb.com/artist.asp?p=131788&o=d)
This is site address: http://www.maniadb.com
I am very sure that not only thousands mp3tag users in Korea would LOVE to see this DB work in mp3tag but also non-koreans would love it.
If you need any, I really mean any translation help, PLEASE let me know. Ill be welcome to assists you for translation. I could get you an apikey if you need.
This post has been edited by veritas: Sep 16 2010, 01:38
Go to the top of the page
+Quote Post
dano
post Sep 16 2010, 09:42
Post #2
Moderator
Group: Moderators
Mp3tag Version: 2.55a
Here is a simple album search.
You need to insert an API key before you can use it!
updated
This post has been edited by dano: Dec 15 2012, 19:09
Attached File(s)
Attached File  maniadb_Search_by__Album_03.zip ( 1.33K ) Number of downloads: 302
+Quote Post
veritas
post Sep 16 2010, 16:41
Post #3
Member
Group: Full Members
QUOTE (dano @ Sep 16 2010, 17:42) *
You rocks!!
Thanks you for the work.
I have go through through some tests, and I got some Error showing up.
especially when album with muti-disks or Various Artists.
I think it works fine with single artist and single disk.
Here are some examples,
1. http://www.maniadb.com/album.asp?a=333762 (Various Artists)
2. http://www.maniadb.com/album.asp?a=114457
(multi-disks)
3. http://www.maniadb.com/album.asp?a=336451
(Various Artists)
4. http://www.maniadb.com/album.asp?a=145098
(Various Artists)
Thanks again for this great work!! I am so excited that ManiaDB can finally work with Mp3Tag laugh.gif
This post has been edited by dano: Sep 16 2010, 18:48
+Quote Post
dano
post Sep 16 2010, 18:51
Post #4
Moderator
Group: Moderators
I've added various artists support.
+Quote Post
veritas
post Sep 16 2010, 21:10
Post #5
Member
Group: Full Members
I have tested with several albums and all of them works just fine.
Thank you!
+Quote Post
asdf
post Feb 25 2011, 16:10
Post #6
Member
Group: Full Members
Mp3tag Version: v2.42
[IndexUrl]=http://www.maniadb.com/api/search.asp?key=XXXXXXXXXXXXXXXXXXXX&target=music&option=album&display=20&query=%s laugh.gif
search result
This post has been edited by asdf: Feb 25 2011, 16:13
+Quote Post
veritas
post Sep 2 2011, 21:34
Post #7
Member
Group: Full Members
I have using this script very well for a long time, but, I am not sure if its because of my recent update of mp3tag to 2.49 or some api changes have been made for maniadb, it gives me error of "server connection error : www.maniadb.com" after pressing next button from list of search result.
I have tried to see the script source and analyze the problem but api seems to be working fine and I cant find any possible errors. unsure.gif
Thanks!
+Quote Post
dano
post Sep 2 2011, 22:20
Post #8
Moderator
Group: Moderators
Yes, problem probably because of a new Mp3tag version.
I've added an updated script.
+Quote Post
veritas
post Sep 3 2011, 10:25
Post #9
Member
Group: Full Members
QUOTE (dano @ Sep 3 2011, 06:20) *
Hi dano,
Thanks for the update. But the problem still persists.
I have downloaded the v2 version and edited the xxxxx to api key and tried in my 2.49 and I still get the same error message, "server connection error : www.maniadb.com".
I look and compare the v1 and v2 script and only difference I can find was album url ending with one equal or with two equals.
Thanks.
My bad.
I was putting the source to \Program Files\mp3tag\data\sources and thats why it didnt work.
saving src to %appdata%\Roaming\Mp3tag\data\sources fixed problem
This post has been edited by veritas: Sep 3 2011, 10:39
+Quote Post
veritas
post Jul 24 2012, 19:28
Post #10
Member
Group: Full Members
Hi dano,
after updating my mp3tag to v2.52 this script has stopped working.
if its not difficult for you, can you give us update of this script for 2.52?
Thanks!
+Quote Post
dano
post Jul 24 2012, 20:16
Post #11
Moderator
Group: Moderators
It still works for me. What's your error message?
+Quote Post
veritas
post Jul 25 2012, 15:30
Post #12
Member
Group: Full Members
QUOTE (dano @ Jul 25 2012, 04:16) *
Oh, i get it.
It returns connection error when the data of album is empty like "http://www.maniadb.com/album.asp?a=712772"
your script is just fine
Thanks anyway!
+Quote Post
veritas
post Dec 15 2012, 04:49
Post #13
Member
Group: Full Members
Hi dano,
I think ManiaDB have just updated their xml sturcture, resulting your script to return duplicated track list.
Ex. if an album has song "ABC" and "DEF"
1. ABC
2. ABC
3. DEC
4. DEC
i tried to fix it myself but failed sad.gif need your assistence. Thanks! walkman.gif
+Quote Post
dano
post Dec 15 2012, 19:11
Post #14
Moderator
Group: Moderators
try the update
+Quote Post
veritas
post Dec 16 2012, 07:38
Post #15
Member
Group: Full Members
QUOTE (dano @ Dec 16 2012, 03:11) *
try the update
Its perfect.
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 25th May 2013 - 12:07
