Nov 19 2010, 15:04
Post
#1
![]() Developer Group: Admin Posts: 7621 Joined: 12-December 01 From: Germany, Dresden Member No.: 203 Mp3tag Version: 2.55a |
I've just released Mp3tag v2.47!
Changes of the new version include: Actions menu The actions feature which was well hidden under the converter menu now has a dedicated top-level menu where all action groups are accessible via menu items. Tag fields renamed With this release some of the tag fields that are used for format strings, actions, columns, exports, and filters are renamed to have more accessible and intuitive names. This also means that all parts of Mp3tag where you have used the old names have to be updated. We know that this is an invasive change but think that it was a step necessary to keep it everything maintainable and understandable for new users of the program. Please see Tag fields in Mp3tag for an updated list. Amazon Amazon has limited access to their web service to 2000 requests per hour. That means that you might get an occassional error 503 when using the Amazon tag source. However, the limit is reset each hour so you can try again later if it is not working for you. As usual, there is more to discover in the Changelog. You can download the new version from http://mp3tag.de/en/download.html Thanks to all who tested the Development Builds and gave feedback on the forums! Enjoy Kind regards, Florian -------------------- |
Nov 19 2010, 18:48
Post
#2
Member Group: Full Members Posts: 8 Joined: 18-October 10 Member No.: 13089 Mp3tag Version: 2.48 |
I just updated and looked at the list of fields, but only ALBUMSORTORDER changes to ALBUMSORT, the other mentioned fields stayed as ARTISTSORTORDER, BAND, BANDSORTORDER, ITUNES..., TITLESORTORDER, ....
This post has been edited by HostedDinner: Nov 19 2010, 18:49 |
Nov 19 2010, 21:38
Post
#3
Member Group: Members Posts: 1 Joined: 19-November 10 From: Harrow, UK Member No.: 13242 Mp3tag Version: 2.47 |
I've just updated to 2.47 too and am also having problems with some of the renamed fields. I'm trying to setup an action to format a value for TITLE. However, the Format Value dialog lists TITLESORTORDER (old name) and TILETITLE (whatever that is) but not TITLE. I also noticed SETSUBTITLESUBTITLE a little earlier in the list.
Nov 19 2010, 21:42
Post
#4
I just updated and looked at the list of fields, but only ALBUMSORTORDER changes to ALBUMSORT, the other mentioned fields stayed as ARTISTSORTORDER, BAND, BANDSORTORDER, ITUNES..., TITLESORTORDER, .... I'm working on this right now. Thanks for pointing. I've just updated to 2.47 too and am also having problems with some of the renamed fields. I'm trying to setup an action to format a value for TITLE. However, the Format Value dialog lists TITLESORTORDER (old name) and TILETITLE (whatever that is) but not TITLE. I also noticed SETSUBTITLESUBTITLE a little earlier in the list. You've probably used v2.46d at some point which was really in beta stage. It messed with the list of fields in a way which is unfortunately not automatically fixable by Mp3tag's upgrading mechanism. -------------------- |
Nov 19 2010, 21:57
Post
#5
I've just released v2.47a which addresses the missing update of the field names list some users were experiencing.
Thanks again for pointing! Kind regards Florian -------------------- |
Nov 20 2010, 18:19
Post
#6
Now there is the right stuff about the SORT Things, but I noticed that there is still no TITLE Tag anymore in the dropdown list. Files with the TITLE Tag are shown as TITLE, but when I want to add a title, its not on that list. There is only TITLESORT. (Don't know if it was since 2.47 or 2.47a)
I updated from 2.46a to 2.47 to 2.47a. EDIT: It's at the end of TAGGINGTIME, now its know as TAGGINGTIMETITLE. And there is something wrong with SETSUBTITLESUBTITLE This post has been edited by HostedDinner: Nov 20 2010, 18:33 |
Nov 21 2010, 04:59
Post
#7
Member Group: Members Posts: 1 Joined: 21-November 10 Member No.: 13252 Mp3tag Version: 247a |
I was wondering. Media Monkey software has developed software to avoid the 503 error code. Their software use to generate the same code, but it no longer does. Will MP3 implement similar code to eliminate the 503 error?
Thanks in advance. This post has been edited by dano: Nov 21 2010, 10:20 |
Nov 21 2010, 16:23
Post
#8
I simply fixed the problem by reinstalling everything, but this shouldn't be the only solution...
Nov 23 2010, 02:02
Post
#9
Member Group: Full Members Posts: 5 Joined: 14-February 09 Member No.: 8539 Mp3tag Version: 2.42 |
BAND to ALBUMARTIST…Oh! NO!
BAND should be back to its original use and just name it BAND. This tag should write it to TXXX:ALBUM ARTIST for foobar2000. although it's a customize column, I think its really more suitable for present this tag. This post has been edited by KidWM: Nov 23 2010, 02:14 |
Nov 23 2010, 23:48
Post
#10
Member Group: Members Posts: 3 Joined: 21-May 07 Member No.: 4969 Mp3tag Version: 2.47a |
Florian, what's the best procedure to fix "TAGGINGTIMETITLE" and bring back "TITLE"?
Is there any way to avoid deleting mp3tag.cfg? |
Nov 24 2010, 05:42
Post
#11
Member Group: Full Members Posts: 11 Joined: 12-October 10 Member No.: 13058 Mp3tag Version: 2.46a |
Hey Florian,
Am I crazy or the 2.46x installer offered an option to a portable installation (which I am using, to sync among several PCs tehehehe), that is gone in 2.47a? |
Nov 24 2010, 10:59
Post
#12
![]() Moderator Group: Moderators Posts: 5506 Joined: 4-September 03 From: Germany Member No.: 201 Mp3tag Version: 2.55a |
There was no portable option in the installer.
But you can create portable versions: http://forums.mp3tag.de/index.php?showtopic=976#entry23162 -------------------- |
Nov 24 2010, 11:14
Post
#13
Florian, what's the best procedure to fix "TAGGINGTIMETITLE" and bring back "TITLE"? Is there any way to avoid deleting mp3tag.cfg? It will be soon. Stay tuned and don't delete your configuration -------------------- |
Nov 25 2010, 02:06
Post
#14
Thanks! I'll sit tight
Nov 25 2010, 04:04
Post
#15
Ohhh thanks a lot dano, I must have forgotten of when I read that topic linked....
Lo-Fi Version | Time is now: 25th May 2013 - 02:59 |
