IPB
> [F] SUBTITLE Tag Missing In LOV on Edit tag info Dialog, The SUBTITLE tag is not existing in the "Edit tag info" dial
Ravefiend
post Nov 30 2010, 15:47
Post #1
Member
Group: Members
Mp3tag Version: 2.47a
In according to Tag field mappings, ID3v2.3 uses TIT3 for SUBTITLE. It is not uncommon to have this information yet it does not show up in the LOV.
1. Pick an MP3 file
2. Extended Tags....
3. Add field...
--> Opens up the Edit tag info dialog
4. The Field: LOV does not contain SUBTITLE
This post has been edited by Ravefiend: Nov 30 2010, 15:48
Go to the top of the page
+Quote Post
dano
post Nov 30 2010, 16:12
Post #2
Moderator
Group: Moderators
Mp3tag Version: 2.55a
- Make sure you have Mp3tag v2.47b
- You can use "Reset fields" function to get all default fields in the LOV if it is still not there
+Quote Post
Ravefiend
post Nov 30 2010, 21:20
Post #3
Member
Group: Members
QUOTE (dano @ Nov 30 2010, 16:12) *
Tried that but no luck either. Interestingly enough is that that the LOV does have SETSUBTITLESUBTITLE, which seems to indicate that it somehow combined both SETSUBTITLE and SUBTITLE.
I'm seeing this too in the mp3tag.cfg when using the Save configuration... option:
CODE
RATING WMP RELEASETIME SETSUBTITLESUBTITLE TAGGINGTIMETITLE TITLESORT
Yes, the problem is my current installation because a fresh install doesn't have this problem. The only 'reset' option I came across is Tools --> Restore all Input Fields but that doesn't fix it. Neither one of them ever was shown as column so I'm still curious to know how Mp3tag ended up gluing those two tags together.
This post has been edited by Ravefiend: Nov 30 2010, 21:27
+Quote Post
dano
post Nov 30 2010, 22:13
Post #4
Moderator
Group: Moderators
It can only be solved with Mp3tag v2.47b
Go to Extended Tags, Edit a field...
Attached thumbnail(s)
+Quote Post
Ravefiend
post Nov 30 2010, 22:35
Post #5
Member
Group: Members
QUOTE (dano @ Nov 30 2010, 22:13) *
Right, so that's the Reset option you were talking about. Didn't came across any reference of that in the document nor on the forum guides eg. http://forums.mp3tag.de/index.php?showtopic=978
Thx a lot Dano!
+Quote Post
dano
post Nov 30 2010, 23:01
Post #6
Moderator
Group: Moderators
It's brand new, to fix the issues with the tag field list.
There are some topics in the forum about this issue, like
http://forums.mp3tag.de/index.php?showtopic=12565
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 20th June 2013 - 10:09
