Dec 6 2010, 10:52
Post
#1
![]() Member Group: Members Posts: 2 Joined: 6-December 10 From: London Member No.: 13352 Mp3tag Version: 2.47 |
I have mp3tag on my PC because I cannot find a Mac OSX equivalent which means transferring my mp3 purchases between machines because a major dance music retailer has just decided to tag it's mp3's with the APE convention and not ID3's.
Does anyone know of any software that works with Mac Intels where I can batch edit my files from APE to ID3? |
Dec 6 2010, 12:10
Post
#2
Member Group: Full Members Posts: 299 Joined: 16-February 08 From: SE-Asia Member No.: 6480 Mp3tag Version: 2.55 |
-------------------- Life is too short, enjoy it |
Jun 10 2011, 19:23
Post
#3
Member Group: Full Members Posts: 134 Joined: 18-February 06 Member No.: 2773 Mp3tag Version: 2.46a |
I have mp3tag on my PC because I cannot find a Mac OSX equivalent which means transferring my mp3 purchases between machines because a major dance music retailer has just decided to tag it's mp3's with the APE convention and not ID3's. Does anyone know of any software that works with Mac Intels where I can batch edit my files from APE to ID3? puddletag, and here's a quick link to help you get it installed on OSX: http://sourceforge.net/apps/phpbb/puddleta...;t=42&p=231 |
Jun 10 2011, 22:56
Post
#4
I ended up using Wine on my Mac which creates a virtual windows partition on the mac's drive allowing the use of windows based software.
Wine |
Jun 11 2011, 01:37
Post
#5
I ended up using Wine on my Mac which creates a virtual windows partition on the mac's drive allowing the use of windows based software. Wine you'd do well to try puddletag, it runs natively and its a lot more than just a drop in replacemet for mp3tag on *nix environments |
Feb 7 2013, 10:40
Post
#6
Member Group: Full Members Posts: 51 Joined: 5-July 09 From: Latvia Member No.: 10541 Mp3tag Version: 2.43 |
If someone uses mp3Tag v-2.54.app in the MAC 10.6., Then it is resolved language code issue?
I Mp3tag the match represented to scribble file names if there is a non-English letters! http://content7-foto.inbox.lv/albums/i/i_e...at-15-12-05.png 1. - after convert code page in russian 1251 4. file not faound - any file by any action the name changes 5. - file name in a MAC 6. - the same file names in a mp3Tag. Similar problems with specific German, Latvian, Russian, etc. letters. |
Feb 24 2013, 11:12
Post
#7
Anybody used Mp3tag to MAC?
Mar 9 2013, 17:35
Post
#8
![]() Member Group: Full Members Posts: 3140 Joined: 9-December 09 From: Norddeutschland / Northern Germany Member No.: 11458 Mp3tag Version: 2.55a |
If someone uses mp3Tag v-2.54.app in the MAC 10.6., Then it is resolved language code issue? I Mp3tag the match represented to scribble file names if there is a non-English letters! http://content7-foto.inbox.lv/albums/i/i_e...at-15-12-05.png 1. - after convert code page in russian 1251 4. file not faound - any file by any action the name changes 5. - file name in a MAC 6. - the same file names in a mp3Tag. Similar problems with specific German, Latvian, Russian, etc. letters. AFAIK the Windows file system uses the ISO standard to encode letters. DOS uses ANSI - which needed the codepage to map the characters. MP3tag uses the functions of the underlying OS to write the filenames. So it should be a problem of the settings of your emulation to get the characters all mixed up. If you are not quite sure if the filename has illegal characters you could try some filenames with the converter tag-filename and enclose the whole mask in the $validate() function, e.g. (taken from the help file): $validate(%artist% - %album% - %track% - %title%,_) perhaps this cuts out the strange characters This post has been edited by ohrenkino: Mar 9 2013, 17:35 -------------------- 42 - wie war die Frage / what was the question / comment était la question
Mar 9 2013, 22:16
Post
#9
(taken from the help file): $validate(%artist% - %album% - %track% - %title%,_) perhaps this cuts out the strange characters O, no - the thing is elsewhere! The Mp3Tag.app in a MAC OS 10.6.X can see and edit the tags, but can not edit the file names. If I edit the tag into russian 1251 encode, when they turn into "????" (It was just an example only). A large part of the various Cyrillic encodes MAC does not see properly only into Mp3Tag.app window, even though it is set to "Windows Cyrillic"! But out of Mp3Tag.app window - Cyrillic encodes folders MAC see property. It is only MAC and Mp3Tag.app problem. Mp3tag.exe in the Windows these problems have not. |
Mar 10 2013, 10:34
Post
#10
I see, sorry to have wasted your time. I do not have a Mac ...
Lo-Fi Version | Time is now: 18th May 2013 - 06:23 |
