Jan 24 2011, 21:21
Post
#1
Member Group: Full Members Posts: 15 Joined: 6-July 07 Member No.: 5224 Mp3tag Version: 2.48 |
There appears to be a mismatch between how MediaMonkey and MP3TAG handle custom fields on flac and mp3 files. Maybe others also, but I have only tested flac and mp3.
I don't know if this is actually a bug, or if it is, who owns it, so I'm posting this in both MediaMonkey and MP3TAG forums. In MediaMonkey, the "real name" of the first custom field (for all files, apparently - both mp3 and flac) is SONGS-DB_CUSTOM1. This appears in MP3TAG as an extended field - COMMENT SONGS-DB_CUSTOM1. In MP3TAG, the same field for a flac file appears as an extended filed with just CUSTOM1. I have no idea which is "correct," if either. I just want the applications to work together - which means that when I set the field in MP3TAG I would like the same value to appear in MediaMonkey. Of course, I can put both values in the MP3TAG panel, and remember to set both, or set the correct one depending on which type of file I'm looking at. But I use several custom fields to help organize my music, and doing this all of the time would be a hassle. thnx, . |
Jan 24 2011, 21:58
Post
#2
![]() Moderator Group: Moderators Posts: 5504 Joined: 4-September 03 From: Germany Member No.: 201 Mp3tag Version: 2.55a |
MM does not use the same kind of custom fields for these file formats so this is not a bug.
But you can configure Mp3tag to show both fields with the same name in the program. At Tools > Options > Tags > Mapping add ID3v2 | COMMENT SONGS-DB_CUSTOM1 | Custom1 Now for both mp3 and flac you can use the name Custom1 in Mp3tag. -------------------- |
Jan 25 2011, 01:02
Post
#3
MM does not use the same kind of custom fields for these file formats so this is not a bug. But you can configure Mp3tag to show both fields with the same name in the program. At Tools > Options > Tags > Mapping add ID3v2 | COMMENT SONGS-DB_CUSTOM1 | Custom1 Now for both mp3 and flac you can use the name Custom1 in Mp3tag. There apparently really are two different fields - in two different locations. Does this mapping mean that a single update in mp3tab updates both fields?? A single update in MediaMonkey shows in both places?? thnx, . |
Jan 25 2011, 11:59
Post
#4
QUOTE Does this mapping mean that a single update in mp3tab updates both fields?? It does not write two fields to one file but the "right" field to each file. QUOTE A single update in MediaMonkey shows in both places?? No, only in Custom1. You have now one field in Mp3tag that works for both audio formats. -------------------- |
Lo-Fi Version | Time is now: 21st May 2013 - 15:10 |
