May 26 2011, 02:28
Post
#1
Member Group: Members Posts: 2 Joined: 26-May 11 Member No.: 14540 Mp3tag Version: 2.48e |
I have an mp3 file whose title tag contains a slash character "/". When I use the convert function in mp3tag to rename the file based on its tags, it omits the "/". For example, if the title tag is "16/05" and the artist tag is "Don Bigg", after the conversion (%artist% - %title%), the filename comes out as "Don Bigg - 1605". Does anyone know why does that happen or how to avoid it?
Thank you beforehand. This post has been edited by wsdoud: May 26 2011, 02:29 |
May 26 2011, 04:14
Post
#2
Member Group: Full Members Posts: 301 Joined: 16-February 08 From: SE-Asia Member No.: 6480 Mp3tag Version: 2.55a |
I have an mp3 file whose title tag contains a slash character "/". When I use the convert function in mp3tag to rename the file based on its tags, it omits the "/". For example, if the title tag is "16/05" and the artist tag is "Don Bigg", after the conversion (%artist% - %title%), the filename comes out as "Don Bigg - 1605". Does anyone know why does that happen or how to avoid it? Thank you beforehand. This is because the '/' is an illegal character in a filename. http://msdn.microsoft.com/en-us/library/aa...v=vs.85%29.aspx Use any character in the current code page for a name, including Unicode characters and characters in the extended character set (128–255), except for the following: The following reserved characters: < (less than) > (greater than) : (colon) " (double quote) / (forward slash) \ (backslash) | (vertical bar or pipe) ? (question mark) * (asterisk) -------------------- Life is too short, enjoy it |
Jun 6 2011, 15:19
Post
#3
This is because the '/' is an illegal character in a filename. http://msdn.microsoft.com/en-us/library/aa...v=vs.85%29.aspx Use any character in the current code page for a name, including Unicode characters and characters in the extended character set (128–255), except for the following: The following reserved characters: < (less than) > (greater than) : (colon) " (double quote) / (forward slash) \ (backslash) | (vertical bar or pipe) ? (question mark) * (asterisk) Oh OK! In fact, I have Mp3tag installed on Mac OS X ('/' character is allowed in filenames) using Winebottler, so I guess I'd have to add the '/' manually. Thanks! |
Jun 7 2011, 12:31
Post
#4
Member Group: Full Members Posts: 88 Joined: 23-September 08 Member No.: 7617 Mp3tag Version: 2.51 |
Jun 7 2011, 12:36
Post
#5
In fact, I have Mp3tag installed on Mac OS X ('/' character is allowed in filenames) using Winebottler, so I guess I'd have to add the '/' manually. This is not recommended because of portability of such files. I concur with LosMintos, why don't you use a '-' (dash) instead ? From 16/05 to 16-05 it doesn't looks that bad -------------------- Life is too short, enjoy it |
Jun 7 2011, 12:42
Post
#6
![]() Member Group: Full Members Posts: 1572 Joined: 15-March 09 From: Germany Member No.: 9103 Mp3tag Version: 2.50 |
Lo-Fi Version | Time is now: 19th June 2013 - 17:45 |
