May 29 2011, 07:45
Post
#1
Member Group: Full Members Posts: 9 Joined: 29-May 11 Member No.: 14556 Mp3tag Version: 2.49 |
Hi everyone!
I have been working on getting my script up and running , but cant seem to figure out how to give an album an unique ID number. The script i have so far: CODE $loop(%_folderpath%)%title%;$ifgreater($strstr($lower($get(memdirectory)),$lower(%_directory%)),0,test($get(memcounter)),$put(memcounter,%_counter%));$puts(memdirectory,%_directory%); I use $strstr($lower($get(memdirectory)),$lower(%_directory%)) to compare the current directory with the previous directory (memdirectory) and determine if this is true (1) or untrue (0). I cannot figure this out and have been working 6 hours on it...... This is what i would like to accomplish, but i guess i am just to stupid to figure it out... ![]() I hope some of you code wizards can help me out |
May 29 2011, 09:31
Post
#2
![]() Member Group: Full Members Posts: 4129 Joined: 26-May 06 From: Wuppertal, Germany, Planet Earth Member No.: 3194 Mp3tag Version: 2.54 |
... I have been working on getting my script up and running , but cant seem to figure out how to give an album an unique ID number. ... Hi 'necrosis', please can you elaborate what you want to achieve? What it the reason and what is the goal of your scripting efforts? Do you need a simple running counter number per album in a small set of albums? Do you need a worlwide everlasting unique id (GUID) per album? DD.20110529.1032.CEST -------------------- * Beyond that, don't ask, when you don't know what to do with the answer. *
♥ home is where the heart is ♥ |
May 29 2011, 14:04
Post
#3
Hi 'necrosis', please can you elaborate what you want to achieve? What it the reason and what is the goal of your scripting efforts? Do you need a simple running counter number per album in a small set of albums? Do you need a worlwide everlasting unique id (GUID) per album? DD.20110529.1032.CEST Hi DetlevD Thank you for your quick response. Because i have so many music, I want to organize and import my complete mp3 collection within a webbased collection tool. Then i want to link this to (for example XBMC), and listen to my music when en where i want. For this to work i need to create a CateroryID and a ProductID (Those are just the field names the tool uses). Please take a look at my screenshot, where I circled the red parts in what i despreately try to achieve: The script needs to generate, for each directory (Albums) and sub directory's, an unique CategoryID number (not need to be worldwide unique, just within the tool). Within these directory's (CategoryID) are MP3 songs. These need to get an unique ProductID according to the CategoryID. My idea to keep it simple is to just append *.1, *.2 etc.. So for example my screenshot. The first album from the top gets an unique CatalogID numer 1 and a unique ProductID for song 1 => 1.1 and song2 =>1.2 I hope this makes things more clear? Thank you for all your help, as i cant seem to figure things out! This post has been edited by necrosis: May 29 2011, 14:34 |
May 29 2011, 15:35
Post
#4
... I want to organize and import my complete mp3 collection within a webbased collection tool. For this to work i need to create a CateroryID and a"ProductID" (Those are just the field names the tool uses. ... generate for each directory (and sub directory's) an unique ID number (not need to be worldwide unique, just within the tool). Within these directory's are MP3 songs. These need to get an unique ProductID according to the CategoryID (it just append*.1, *.2 etc..) ... As I understand the situation ... - You speak of CatalogID, CategoryID, ProductID, so CatalogID and CategoryID are used as synonyms? - Does the CategoryID have the importance of Genre or other musical classification? Or is it in your case of application just the same as the folderpath? - The ProductID is needed per track? You want to create the PRoductID simply by appending a running number to the CategoryID? - Does it be true, that all IDs are not visible to the user, must not be human readable, and are only used internally by the database? I recommend to use a GUID as ProductID per track and a GUID per Album as CategoryID. GUIDs can be created rather easy. See also ... http://forums.mp3tag.de/index.php?showtopi...ost&p=52341 Once the GUID list file has been created, the converter Textfile - Tag can import the GUIDs into the tracks. If you want to create your own running number based routine, then you may play with the following MTE export script to understand how to code a $loop() ... $loopend() structure and how to use %_counter% placeholder. Be aware that the Mp3tag Export Scripting Language does not support to $get() a $put() variable within a loop, which has been defined outside of the loop. $filename($getEnv('USERPROFILE')'\Desktop\Mp3tag.Export.txt',ANSI) $loop(%_folderpath%,1)$loopend()'1: All FolderCount = '%_max_counter% $loop(%_path%)$loopend()'2: All FileCount = '%_max_counter% $repeat('=',50) $loop(%_folderpath%,1) '3: FolderNumber = '%_counter% '4: FolderPath = '%_folderpath% $loop(%_path%)$loopend()'5: FileCount = '%_max_counter% $loop(%_path%) '6: FileNumber = '%_counter% '7: FilePath = '%_path% $loopend()$repeat('-',50) $loopend() DD.20110529.1637.CEST This post has been edited by DetlevD: May 29 2011, 15:36 -------------------- * Beyond that, don't ask, when you don't know what to do with the answer. *
Jun 2 2011, 03:33
Post
#5
As I understand the situation ... - You speak of CatalogID, CategoryID, ProductID, so CatalogID and CategoryID are used as synonyms? - Does the CategoryID have the importance of Genre or other musical classification? Or is it in your case of application just the same as the folderpath? - The ProductID is needed per track? You want to create the PRoductID simply by appending a running number to the CategoryID? - Does it be true, that all IDs are not visible to the user, must not be human readable, and are only used internally by the database? I recommend to use a GUID as ProductID per track and a GUID per Album as CategoryID. GUIDs can be created rather easy. See also ... http://forums.mp3tag.de/index.php?showtopi...ost&p=52341 Once the GUID list file has been created, the converter Textfile - Tag can import the GUIDs into the tracks. If you want to create your own running number based routine, then you may play with the following MTE export script to understand how to code a $loop() ... $loopend() structure and how to use %_counter% placeholder. Be aware that the Mp3tag Export Scripting Language does not support to $get() a $put() variable within a loop, which has been defined outside of the loop. $filename($getEnv('USERPROFILE')'\Desktop\Mp3tag.Export.txt',ANSI) $loop(%_folderpath%,1)$loopend()'1: All FolderCount = '%_max_counter% $loop(%_path%)$loopend()'2: All FileCount = '%_max_counter% $repeat('=',50) $loop(%_folderpath%,1) '3: FolderNumber = '%_counter% '4: FolderPath = '%_folderpath% $loop(%_path%)$loopend()'5: FileCount = '%_max_counter% $loop(%_path%) '6: FileNumber = '%_counter% '7: FilePath = '%_path% $loopend()$repeat('-',50) $loopend() DD.20110529.1637.CEST Wow!! Thank you for your response, this helped me a great deal in getting me going :-) Is it also possible to get the CATEGORYID (see screenshot) within every row? Now you first loop the CATEGORYID and then loop the PRODUCTID. I tried again for one day now to get the CATEGORYID listed in the same row as the PRODUCTID. The output right now is like this: 1: All FolderCount = 7 2: All FileCount = 20 ================================================== 3: FolderNumber = 1 4: FolderPath = \\Africa_HiTech-Out_In_The_Streets-(WAP315DV)-WEB-2011-KOUALA\ 5: FileCount = 1 6: FileNumber = 1 7: FilePath = \\Africa_HiTech-Out_In_The_Streets-(WAP315DV)-WEB-2011-KOUALA\01-africa_hitech-out_in_the_streets-kouala.mp3 -------------------------------------------------- 3: FolderNumber = 2 4: FolderPath = \\Appleblim_And_October-NY_Fizzzzz-(PLATTER001)-WEB-2011-320\ 5: FileCount = 2 6: FileNumber = 1 7: FilePath = \\Appleblim_And_October-NY_Fizzzzz-(PLATTER001)-WEB-2011-320\01-appleblim_and_october-ny_fizzzzz.mp3 6: FileNumber = 2 7: FilePath = \\Appleblim_And_October-NY_Fizzzzz-(PLATTER001)-WEB-2011-320\02-appleblim_and_october-fountains_of_paradise.mp3 -------------------------------------------------- But what i try to achieve is 1: All FolderCount = 7 2: All FileCount = 20 ================================================== 3: FolderNumber = 1 4: FolderPath = \\Africa_HiTech-Out_In_The_Streets-(WAP315DV)-WEB-2011-KOUALA\ 5: FileCount = 1 3: FolderNumber = 1 6: FileNumber = 1 7: FilePath = \\Africa_HiTech-Out_In_The_Streets-(WAP315DV)-WEB-2011-KOUALA\01-africa_hitech-out_in_the_streets-kouala.mp3 5: FileCount = 1 -------------------------------------------------- 3: FolderNumber = 2 4: FolderPath = \\Appleblim_And_October-NY_Fizzzzz-(PLATTER001)-WEB-2011-320\ 5: FileCount = 2 3: FolderNumber = 2 6: FileNumber = 1 7: FilePath = \\Appleblim_And_October-NY_Fizzzzz-(PLATTER001)-WEB-2011-320\01-appleblim_and_october-ny_fizzzzz.mp3 5: FileCount = 2 3: FolderNumber = 2 6: FileNumber = 2 7: FilePath = \\Appleblim_And_October-NY_Fizzzzz-(PLATTER001)-WEB-2011-320\02-appleblim_and_october-fountains_of_paradise.mp3 5: FileCount = 2 -------------------------------------------------- I feel so stupid that i cant accomplish this. If i could just use my variables outside the loops my problems would all be solved.. Hope you can help! Thanks for any response from you coding wizards! This post has been edited by necrosis: Jun 2 2011, 03:39 |
Jun 2 2011, 07:51
Post
#6
Wow!! Thank you for your response, this helped me a great deal in getting me going :-) ... Is it also possible to get the CATEGORYID (see screenshot) within every row? Now you first loop the CATEGORYID and then loop the PRODUCTID. I tried again for one day now to get the CATEGORYID listed in the same row as the PRODUCTID. ... I feel so stupid that i cant accomplish this. If i could just use my variables outside the loops my problems would all be solved. ... There are restrictions in the Mp3tag Export Scripting Language, I have pointed out. I assume that it is necessary to create some custom tag-fields, which you fill with the correct values in order to use them in an export. After exporting you can delete the custom tag-fields. Or write two export scripts, which creates text data files for both cases, with the proper values in order to load the values back into the files into the tag-fields using converter 'Textfile - Tag'. Proove your concept of numbering with a serial number. Once you have to insert a new item into the set, you have to renumber the complete set. This is inefficient. DD.20110602.0914.CEST I have pity with you, so I wrote a Mp3tag MTE export script, which generates a VBScript VBS command file, which generates a CSV text file, which can be used as input for the Mp3tag converter 'Textfile- Tag' to set a serial number for each folder and within each folder for each file.
20110602.Export_VBS_SerialNumber.mte ( 5.6K )
Number of downloads: 68DD.20110602.1234.CEST This post has been edited by DetlevD: Jun 2 2011, 11:45 -------------------- * Beyond that, don't ask, when you don't know what to do with the answer. *
Jun 2 2011, 15:23
Post
#7
Number of downloads: 68DD.20110602.1234.CEST I am lost with words on the way you help people with their problems.. This is really fantastic, thank you so much for helping me out on my quest to get my export right and working! Creating some custom tag fields is no problem as long as i don't overwrite the original source file (MP3). I also thought about the two text files option, but wouldn't know where to begin... The .vbs option didn't even come to mind...... The mp3tag generation of the vbs works fine, but when i click on the .vbs to execute i get an Windows Script Host error? Am i missing something or doing something wrong here? ![]() |
Jun 2 2011, 15:41
Post
#8
I am lost with words on the way you help people with their problems.. This is really fantastic, thank you so much for helping me out on my quest to get my export right and working! Creating some custom tag fields is no problem as long as i don't overwrite the original source file (MP3). I also thought about the two text files option, but wouldn't know where to begin... The .vbs option didn't even come to mind...... The mp3tag generation of the vbs works fine, but when i click on the .vbs to execute i get an Windows Script Host error? Am i missing something or doing something wrong here? ![]() I got the script working Now on to figuring out the rest |
Jun 3 2011, 17:05
Post
#9
I got the script working Now on to figuring out the rest Thanks to your help i got everything almost ready for processing :-D Without your help i wouldn't have come this far in a million years! Your examples really given me a boost in understanding MP3TAG its possibilities and limitations. I still have two mayor problem left where i have spend the night on trying to solve (yes again now the fourth day in a row...). Seems like i can't tackle these problems so any help is REALLY appreciated! First problem i am facing: Is the extraction/renaming of mp3 files, here a couple of example files: Cameo-1xtra_Showcase_Live_on_Radio_1_(Jason_Kaye_Guestmix)-CABLE-05-22-2011-uC 3rd_Party-3RD02-noise_factory-1992-sour Dillinja_-_Cybotron-Retail_CD-2001-BOSS_INT Refresh-Your_Skills_Once_In_A_While_By_Pressing_Buttons-2011-404 VA-Hardware_XV-15_Years_Of_Renegade_Hardware-(HWAREXVCD1)-3CD-2011-hM VA-Legendary_Sounds_Volume_1-RIVETCD21-2005-PiCKLE_iNT VA-MOS_The_Mash_Up_Mix_Bass__Mixed_By_The_Cut_Up_Boys-2CD-2011-BPM Kromestar-Bonafied_Hustlahz-(DPH003)-Vinyl-2010-BNP white_label-unknown_artist-bw001-(200x)-sour Basically remove the last part (which can consist out of character and or number) but is not allways present to should check, remove the year and encapsulation (always written as 4 numbers or three numbers and any character e.g. 200x, sometimes accompanied bij encapsulation e.g. (1999) Secondly i would really like to copy the ALBUM ID's to a separate tag field %albumsort%. These ID's are currently not in the Tag fields, but only in the directory name This are ID's like (DPH003), 3RD02 or RIVETCD21). These album ID's are always formatted like this e.g. Any word character times * followed bij two or 3 numbers =>DPH003 Sometimes they are encapsulated bij () and sometimes bij spaces or the - signs. It would be visually nice to give each first character a YUppercase and the ALBUM ID all uppercases. When done i would be ecstatic if the result will show: Cameo-1xtra_Showcase_Live_on_Radio_1_(Jason_Kaye_Guestmix) 3rd_Party-3RD02-noise_factory Dillinja_-_Cybotron-Retail_CD Refresh-Your_Skills_Once_In_A_While_By_Pressing_Buttons VA-Hardware_XV-15_Years_Of_Renegade_Hardware-(HWAREXVCD1)-3CD VA-Legendary_Sounds_Volume_1-RIVETCD21 VA-MOS_The_Mash_Up_Mix_Bass__Mixed_By_The_Cut_Up_Boys-2CD Kromestar-Bonafied_Hustlahz-(DPH003) White_Label-Unknown_Artist-BW001 And be presented cleanly in the output like: Cameo - 1xtra Showcase Live on Radio 1 - (Jason Kaye Guestmix) 3rd Party - Noise_Factory - 3RD02 Dillinja - Cybotron - Retail CD Refresh - Your Skills Once In A While By Pressing Buttons VA - Hardware XV - 15 Years Of Renegade Hardware - HWAREXVCD1 - 3CD VA - Legendary Sounds Volume 1 - RIVETCD21 VA - MOS The Mash Up Mix Bass - Mixed By The Cut Up Boys - 2CD Kromestar - Bonafied Hustlahz - DPH003 White Label - Unknown Artist - BW001 Second Problem Second problem im facing is that when i add new songs to my library and run your awesome vbs script again, everything gets renumbered.... Is there a way to only update new and or changed songs? I thought of using filters? but i don't know if that is the best way to approach this? Maybe store the last catergoryid and productid in a text file and go from there? And that's about it....... Not your everyday problem around here i guess... I feel so stupid that i cant solve these (even after two nights of coding). Thank you all for any help you can give me in trying to solve my technically challenged questions This post has been edited by necrosis: Jun 3 2011, 17:23 |
Jun 3 2011, 18:18
Post
#10
![]() Member Group: Full Members Posts: 3164 Joined: 9-December 09 From: Norddeutschland / Northern Germany Member No.: 11458 Mp3tag Version: 2.55a |
First problem i am facing: Cameo-1xtra_Showcase_Live_on_Radio_1_(Jason_Kaye_Guestmix)-CABLE-05-22-2011-uC If data is as wildly structured as this, I would always use filters to see whether any wildcard action really hits the files I want to manipulate. If I have a look at the examples it looks like the following pattern to me: <data>-<data>_<data>-<garbage> So any string you want to chop off the end from has the pattern underscore<data>hyphen<garbage>. A filter with %_filename% MATCHES ".*-.*_.*-.*" should filter all those that still have a hyphen<garbage> at the end. Then you could perform a replace with regular expression action to chop off the end until you are left with no other hypen than the starting one. One problem that you have to solve for yourself is the wish to in some cases keep data at the end ZITAT VA-Hardware_XV-15_Years_Of_Renegade_Hardware-(HWAREXVCD1)-3CD-2011-hM ... VA - Hardware XV - 15 Years Of Renegade Hardware - HWAREXVCD1 - 3CD and sometimes not. Also the change places bit in ZITAT 3rd_Party-3RD02-noise_factory-1992-sour .... 3rd Party - Noise_Factory - 3RD02 requires a lot of clairvoyance by a program/script... -------------------- 42 - wie war die Frage / what was the question / comment était la question
Jun 11 2011, 03:01
Post
#11
Thanks for your reaction
I have done some serious diggin on ReEx and written a script to do most of what i need! \b[\d0-9]?([a-z]{2,}?[\d0-9]{2,}?|[a-z]{2,}?[\d0-9]+[a-z]+|[a-z]{4,}?[\d0-9]+|[a-z]{2,}?[\d0-9]{2,}?|[\d0-9]+[a-z][\d0-9]+|[\d0-9]{5,})\b 9 times out of 10 it filters out the Album ID: VA-Points_in_Time_007-(GLRPIT007)-CD1-2000-CT_INT XL_Recordings-XLS24CD-SL2-1991-sour It picks up GLRPIT007 and also XLS24CD. I have searched everywhere, but how can use this regex and manage to match these within a directory field and put this in a custom Field? I only see the replace function within mp3tag? |
Jun 13 2011, 15:37
Post
#12
Anybody has knowledge on this?
I have turned to Visual Basic as i believe it is not possible within MP3TAG.... |
Jun 13 2011, 16:24
Post
#13
![]() Moderator Group: Moderators Posts: 5507 Joined: 4-September 03 From: Germany Member No.: 201 Mp3tag Version: 2.55a |
Take a look at the Actions (Alt+5)
Format value with $regexp() function and Replace with regular expression can be used. -------------------- |
Jun 13 2011, 16:42
Post
#14
Take a look at the Actions (Alt+5) Format value with $regexp() function and Replace with regular expression can be used. Hi Dano, Thank you for your response. I looked at that, but i cant seem to figure out how to do this. I do not want to replace anything i just want to match the Albumid within the Directory and place this match in a tag field? Could you please help me? I looked all around the forum and couldn't find any topic related to my problem. This post has been edited by necrosis: Jun 13 2011, 16:44 |
Jun 13 2011, 17:43
Post
#15
Ok this one seems best:
Action type: Guess values Source format: $regexp(%_directory%,'\b\d?([a-z]{2,}?\d{2,}?|[a-z]{2,}?\d+[a-z]+|[a-z]{4,}?\d+|[a-z]{2,}?\d{2,}?|\d+[a-z]\d+|\d{5,})\b',~~~$1~~~,1) Guessing pattern: %dummy%~~~%albumsort%~~~%dummy% * I shortened [\d0-9] to \d -------------------- |
Lo-Fi Version | Time is now: 26th May 2013 - 00:45 |
