Jun 24 2011, 18:21
Post
#1
Member Group: Full Members Posts: 81 Joined: 14-September 10 From: Providence RI Member No.: 12931 Mp3tag Version: 2.52 |
My collection is rather large, its around 43K songs, when I right click on the directory and send them to MP3TAG, the bar load shows X of XXXXX tracks counting up as it loads......and typically moves very fast. Then in certain spots, it literally drags......like 1 to 2 seconds between songs, then continues counting up real fast again. To load up the 43K songs take about 25 minutes from start to finish.
Other times when I only look at say 5K of the songs, it counts quick, and if I close the program and reopen it (reopening the 5K songs immediately) its like lightning when it reloads. Does anyone know why it hangs like that? I know some of the files are over 100Meg in size, all MP3, all "tagged" fairly thee good. It doesn't make sense why sometimes it loads incredible fast, and other times, slow, this behavior has been through out several versions. I am running a core 2 duo, 2GB ram, win7, and the machine is fairly robust, so I know its not an age thing..... Just looking for some possible insight..... Thanks Chris |
Jun 24 2011, 19:04
Post
#2
![]() Member Group: Full Members Posts: 3153 Joined: 9-December 09 From: Norddeutschland / Northern Germany Member No.: 11458 Mp3tag Version: 2.55a |
it literally drags... hard disc cache? Check the hard disk LED during those "hang" times - if it stays on all the time instead of flickering then the internal grooming slows down the access. As you also notice that repeated loads of the same files increases the speed this also indicates that it is a problem/the normal behaviour of the hard disc cache. -------------------- 42 - wie war die Frage / what was the question / comment était la question
Jun 24 2011, 19:56
Post
#3
hard disc cache? Check the hard disk LED during those "hang" times - if it stays on all the time instead of flickering then the internal grooming slows down the access. As you also notice that repeated loads of the same files increases the speed this also indicates that it is a problem/the normal behaviour of the hard disc cache. The harddisk is lit all the time, whether fast or slow, its a 7200 RPM 500GB drive with NCQ.....so it is very fast and robust, over 95MB/s according to HDTACH. Just thought it was odd..... |
Lo-Fi Version | Time is now: 21st May 2013 - 17:00 |
