Jul 26 2011, 15:40
Post
#1
Member Group: Members Posts: 2 Joined: 23-June 11 Member No.: 14746 Mp3tag Version: 2.49 |
Ever since I accidentally discovered that a # in a custom action name will split it into a submenu, I've been using it to create submenus for my actions.
Is there any way to do that for tools? I know tools are stored differently than actions, but trying my luck anyway |
Jul 28 2011, 23:03
Post
#2
Member Group: Full Members Posts: 52 Joined: 4-December 10 Member No.: 13342 Mp3tag Version: 2.53 |
Wow - I had no idea grouping was available in Actions - thanks for the tip. I also discovered that any text prior to the # will result in that text being used as the subgroup name and group actions with the same text prior to the # in the same subgroup.
I am continually impressed with the capabilities of Mp3tag. This post has been edited by rungumprun: Jul 28 2011, 23:04 |
Lo-Fi Version | Time is now: 22nd May 2013 - 14:29 |
