Abbreviations: (will be specified by moderators/administrators)
| [X] | No Bug | [C] | Confirmed Bug Report |
| [F] | Fixed Bug | [LP] | Low Priority Bug Report |
| [AF] | Awaiting Feedback |
Sep 19 2011, 19:30
Post
#1
Member Group: Full Members Posts: 1247 Joined: 25-October 05 Member No.: 2273 Mp3tag Version: - |
When using ALT+T I set RATING MM, the track rating is not recognised by MediaMonkey build 1306. It looks like Mp3tag is creating a field named literally RATING MM rather than the WM/SharedUserRating as documented.
![]() Please could someone verify this on the latest version. |
Sep 19 2011, 20:33
Post
#2
![]() Moderator Group: Moderators Posts: 5506 Joined: 4-September 03 From: Germany Member No.: 201 Mp3tag Version: 2.55a |
The documentation is wrong.
RATING MM is not connected to WM/SharedUserRating -------------------- |
Sep 19 2011, 21:41
Post
#3
The documentation is wrong. RATING MM is not connected to WM/SharedUserRating Thanks Dano. I think that's the problem I reported, no? Or are you suggesting RATING MM is not intended to connect to WM/SharedUserRating? In which case, I wonder a) what RATING MM is for and b) what does connect to WM/SharedUserRating using MM values, if anything. This post has been edited by chrisjj: Sep 19 2011, 21:56 |
Sep 19 2011, 22:07
Post
#4
RATING MM only has a special function on mp3 files with ID3v2 tags.
For wma files, RATING WMP should be compatible with MM because on wma there is only one way to save ratings. -------------------- |
Sep 19 2011, 22:38
Post
#5
RATING MM only has a special function on mp3 files with ID3v2 tags. That's a serious breakage. Florian, will you be fixing this? For wma files, RATING WMP should be compatible with MM because on wma there is only one way to save ratings. Thanks for the workaround. For WMA only, it works fine. Is there really no Mp3tag rating field that works properly for MediaMonkey in different formats? Managing separate fields for different types is a nightmare. This post has been edited by chrisjj: Sep 19 2011, 22:40 |
Sep 22 2011, 17:57
Post
#6
You could add a tag mapping for wma files:
wma | RATING WMP | RATING MM -------------------- |
Sep 26 2011, 20:08
Post
#7
Oct 8 2011, 17:20
Post
#8
Florian, will this be fixed please?
Aug 28 2012, 07:32
Post
#9
Member Group: Full Members Posts: 83 Joined: 15-April 09 From: USA Member No.: 9727 Mp3tag Version: 2.55 |
this sounds really similar to my problem in this thread:
http://forums.mp3tag.de/index.php?showtopic=13378 ...where i can no longer see the "raw data" for popularimeter in the ratings column (for id3 files). based on that and what you guys were saying above, my question is this: can i add a mapping that would let me see the raw data? something like: ID3v2 | popularimeter | RATING or some user invoked unique named column? (i use mainly FLAC and mp3, so i would like both in one column if possible, and i have a handful of wma and m4a as well) would that reveal the raw data? am i making sense, i'm a bit out of my depth? This post has been edited by MrSinatra: Aug 28 2012, 07:59 -------------------- |
Lo-Fi Version | Time is now: 24th May 2013 - 19:01 |
