Jan 17 2012, 21:50
Post
#1
Member Group: Full Members Posts: 9 Joined: 28-July 11 Member No.: 14967 Mp3tag Version: 2.47b |
I have discovered that quite a lot of my mp3's have been hiding away APE tags when I thought I had cleaned them all up.
Looks like mp3tag was not showing me APE tags, but I'm getting confused as to how to do a proper clean up here. What I want ideally is for all my mp3's to JUST have the ID3v2.3 tags and nothing else, but I don't understand how to achieve this. For example a lot of them (when I enable the TAG column) in the display say ID3v2.3(ID3v1 ID3v2.3 APEv2) What is the significance of the bit in brackets and how do I get rid of it! Any pointers appreciated... |
Jan 17 2012, 22:12
Post
#2
![]() Member Group: Full Members Posts: 774 Joined: 18-April 05 Member No.: 1742 Mp3tag Version: 2.55a |
Yes, removing tags is not at all intuitive in Mp3tag.
First, go into Tools > Options (or Ctrl-O) > Tags > Mpeg.
To remove the unwanted tags, highlight the files to be worked on (or Ctrl-A to select all). If under the Read option you checked anything else beside ID3v2 then you intend to copy any data found in the ID3v1 or APE tags into the ID3v2 tag. So press Ctrl-S to Save. Then press Ctrl-R to remove the unwanted tags. This can also be accomplished by pressing the two leftmost buttons in the button bar (floppy disk then red X). This post has been edited by JJ Johnson: Jan 17 2012, 22:14 |
Jan 19 2012, 12:08
Post
#3
Brilliant that works!
Finally I understand it. You’re right it’s not very intuitive. Pesky APE tags all gone Many many thanks |
Lo-Fi Version | Time is now: 19th May 2013 - 01:09 |
