Jan 20 2012, 09:57
Post
#1
Member Group: Full Members Posts: 13 Joined: 19-September 06 Member No.: 3699 Mp3tag Version: 2.36a |
Hi
MP3tag has stopped reading some tags. Here is the explorer view and the MP3tag view. If I take an untagged MP3 and enter the tag using Windows 7 MP3tag also 'seems to knows' there are tags there because it will not write to the files unless the tags are cleared first. Using Windows 7 pro, SP1 64 bit MP3tag v2.49b Mpeg Options are Read ID3v1 ID3v2 APE Write ID3v2 - ID3v2.3 ISO-8859-1 Remove IDv31 APE If I clear the tags then I can write them and MP3tag can read them Any ideas? Thanks Pegleg |
Jan 20 2012, 10:03
Post
#2
![]() Member Group: Full Members Posts: 3154 Joined: 9-December 09 From: Norddeutschland / Northern Germany Member No.: 11458 Mp3tag Version: 2.55a |
Untick the "Read APE" button - or cut and paste all tags. It looks as though you have (empty) APE tags in your files. APE overrules MP3 tags.
(Unfortunately is the screendump missing out the part where mp3tag's column shows the tag versions of the file). -------------------- 42 - wie war die Frage / what was the question / comment était la question
Jan 20 2012, 10:52
Post
#3
![]() Moderator Group: Moderators Posts: 5504 Joined: 4-September 03 From: Germany Member No.: 201 Mp3tag Version: 2.55a |
It always helps opening "View > Extended Tags" [Alt+T] to see all supported tags.
Jan 20 2012, 15:47
Post
#4
Hi Orenkino, Dano
Thanks a million you got it it's the blank APE tags, though it seems you have to shut MP3tag down after unticking the "Read APE" for it to become effective. MP3tags is now back to behaving normally (without read APE selected), and the tag field shows IB3v2.3(IDV3v1 ID3v2.3). I was using copies so it didn't matter but - Much to my chagrin - pasted empty tags. Thanks for the help Pegleg |
Lo-Fi Version | Time is now: 21st May 2013 - 21:18 |
