IPB
> Notice!
> As can be called a tag ?
TGK
post Jan 30 2012, 18:30
Post #1
Member
Group: Full Members
Mp3tag Version: 2.50
Hi !
What is the name tag : "Audio file information webpage"
What is the value entered in the field ?
Go to the top of the page
+Quote Post
pone
post Jan 30 2012, 19:26
Post #2
Member
Group: Full Members
ZITAT(TGK @ Jan 30 2012, 18:30) *
Hi !
Look here:
http://help.mp3tag.de/main_tags.html
WWWAUDIOFILE
I'm not sure what this field is for. May for a link to the web shop where you have bought this file. Or for a link to a page where you have downloaded it (podcasts etc).
I don't think it is used much. Simply WWW is more common for all kinds of http links.
+Quote Post
TGK
post Jan 31 2012, 16:21
Post #3
Member
Group: Full Members
pone
I tried was the name of the field does not display, the tag contains multiple URL - Format : http://www .*****, URL list, separated by commas, with a space - the tag (s) have been registered in another program - "Tag & Rename "
+Quote Post
DetlevD
post Jan 31 2012, 16:48
Post #4
Member
Group: Full Members
Mp3tag Version: 2.54
QUOTE (TGK @ Jan 30 2012, 18:30) *
Hi ! What is the name tag : "Audio file information webpage" What is the value entered in the field ?
Maybe reading these pages can help ...
http://forums.winamp.com/showthread.php?t=334031
Section 4.3.1. URL link frames - details ... http://id3.org/d3v2.3.0
DD.20120131.1649.CET
+Quote Post
TGK
post Jan 31 2012, 19:01
Post #5
Member
Group: Full Members
QUOTE (DetlevD @ Jan 31 2012, 17:48) *
Has read. Tried to insert in the field all variants:
WWWARTIST WOAR "WM/AuthorURL Official artist Web site
WWWAUDIOFILE WOAF "WM/AudioFileURL Official audio file information
WWWAUDIOSOURCE WOAS "WM/AudioSourceURL Official audio source
WWWCOMMERCIALINFO WCOM "WM/PromotionURL
WWWCOPYRIGHT WCOP "CopyrightURL
WWWPAYMENT WPAY"
WWWPUBLISHER WPUB"
WWWRADIOPAGE
Probably which that program I register тег "Audio file information webpage" (Tag and Rename) writes this тег () in a format "ID3 tag version 2.4.0", whether the program mp3Tag теги displays versions "ID3 tag version 2.4.0"? Or only "ID3 tag version 2.3.0"...
I tried to register in the field тега - for its display as it is accepted for the name of fields "ID3 tag version 2.4.0":
WOAR
WOAF
WOAS
WCOM
WCOP
WPAY
WPUB
WORS
All the same doesn't display.
There are still what ideas?
+Quote Post
TGK
Post #6
Member
Group: Full Members
Everything, like would understand
This post has been edited by TGK: Jan 31 2012, 19:13
+Quote Post
DetlevD
post Jan 31 2012, 21:16
Post #7
Member
Group: Full Members
QUOTE (TGK @ Jan 31 2012, 19:01) *
I have totally no clue what you want to achieve.
Try this ...
- open Mp3tag
- select a mp3 file for testing
- press [Alt+T] to open the dialog "Extended tags..."
- if the tag-field WWWARTIST does not exist, then create this tag-field
- press key [INS] and fill into the edit field the name WWWARTIST
- select the edit field "Value" and fill in the URL "http://www.thepops.de" (without the quote characters)
- close the edit dialog with [OK]
- close the extended tags dialog with [OK] to save the changes
- close Mp3tag
- check out how this new tag-field will be displayed from within other tagger applications or players
For example, foobar2000 displays the Mp3tag's tag-field "WWWARTIST" as the tag-field "ARTIST WEBPAGE URL" with the stored value "http://www.thepops.de".
DD.20120131.2117.CET
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 24th May 2013 - 19:29
