Feb 22 2012, 10:08
Post
#1
Member Group: Full Members Posts: 14 Joined: 21-November 11 Member No.: 15609 Mp3tag Version: 2.49 |
I am successfully exporting my collection details to csv and can bring it into excel. I use | as a deliminator. (The default ; didn't work because too many titles have that too). Some of my tags have multiple entries, typically genre, and use // as separator for them. The exported file seems to drop anything after // in genre so I only get the first genre item in the csv Can I do anything fix this? Thanks Mark This post has been edited by m4rk: Feb 22 2012, 10:08 |
Feb 22 2012, 10:42
Post
#2
![]() Member Group: Full Members Posts: 1571 Joined: 15-March 09 From: Germany Member No.: 9103 Mp3tag Version: 2.50 |
from the help files:
ZITAT $meta(x) returns all values of field x (e.g. $meta(artist)). If multiple values of that field exist, they are separated with ", ". $meta(x,n) returns the nth value of field x (where n starts at 0, e.g. $meta(artist,1)). $meta_sep(x,sep) returns all values of field x (e.g. $meta_sep(artist,; )). If multiple values of that field exist, they are separated with sep. http://help.mp3tag.de/main_scripting.html#metadata This post has been edited by pone: Feb 22 2012, 10:44 |
Feb 22 2012, 11:01
Post
#3
Hi thanks for that.... looks I need help for the help files!! I have no idea what that all means. It is fun learning though The more I use mp3tag the more I am impressed with it. You can do just about anything but it takes quite a bit learning for a novice and much testing to figure it out. Thanks, I think that has pointed me in the right direction |
Feb 22 2012, 11:14
Post
#4
When you are exporting your tags, you are using an export script.
Open that script and replace all instances of %genre% with $meta(genre) You have to do this with all tag fields where you have multivalue tags. This post has been edited by pone: Feb 22 2012, 11:24 |
Feb 22 2012, 12:03
Post
#5
When you are exporting your tags, you are using an export script. Open that script and replace all instances of %genre% with $meta(genre) You have to do this with all tag fields where you have multivalue tags. Great, that tip helps a lot. I had found the export scripts and made a simple change. I changed the default delimiter and saved it as a new script but I must admit to being a bit clueless as to how they worked. Is there a help section to explain how the looping part works? I didn't see it in 'scripting' help section? Mark This post has been edited by m4rk: Feb 22 2012, 12:43 |
Feb 22 2012, 12:29
Post
#6
Is there a help section to explain how the looping part works? I didn't see it in 'scripting' help section? yes, in the export help section http://help.mp3tag.de/options_export.html#syntax : ZITAT $loop(%fieldname%) starts a new loop. The loop data is sorted by the fieldname. $loopend() ends a loop. If you want to limit the loop output to a certain number of entries, simply use $loop(%fieldname%,num). This is useful to eliminate duplicate records (num=1). So if you have something like QUELLTEXT $loop(%_filename_ext%)%title%;%artist%;%album%; $loopend() the loop writes %title%;%artist%;%album%; + linebreak for every new %_filename_ext%. Whereas this loop QUELLTEXT $loop(%album%)%albumartist%;%album%;%year% $loopend() would write %albumartist%;%album%;%year% + linebreak for every new %album%. So it would skip all files with the same %album% value after writing the values of the first file. This post has been edited by pone: Feb 22 2012, 12:33 |
Feb 22 2012, 12:45
Post
#7
yes, in the export help section http://help.mp3tag.de/options_export.html#syntax : So if you have something like CODE $loop(%_filename_ext%)%title%;%artist%;%album%; $loopend() the loop writes %title%;%artist%;%album%; + linebreak for every new %_filename_ext%. Whereas this loop CODE $loop(%album%)%albumartist%;%album%;%year% $loopend() would write %albumartist%;%album%;%year% + linebreak for every new %album%. So it would skip all files with the same %album% value after writing the values of the first file. Thanks, I now have it working eg FLAC tag genre like this: R&B\\Soundtrack\\Rock Replaced %genre% with $meta_sep(genre,\\) in csv export script now xls import of resultant csv has R&B\\Soundtrack\\Rock in genre column Perfect Thanks again for your help, Mark This post has been edited by m4rk: Feb 22 2012, 12:48 |
Feb 22 2012, 12:51
Post
#8
yes, in the export help section http://help.mp3tag.de/options_export.html#syntax : So if you have something like CODE $loop(%_filename_ext%)%title%;%artist%;%album%; $loopend() the loop writes %title%;%artist%;%album%; + linebreak for every new %_filename_ext%. Whereas this loop CODE $loop(%album%)%albumartist%;%album%;%year% $loopend() would write %albumartist%;%album%;%year% + linebreak for every new %album%. So it would skip all files with the same %album% value after writing the values of the first file. Again very useful info. I was having to use Excel Office 2007 and the 'remove duplicates' function to create a simple list of albums and their genres. |
Feb 22 2012, 13:17
Post
#9
Again very useful info. I was having to use Excel Office 2007 and the 'remove duplicates' function to create a simple list of albums and their genres. Maybe I am pushing my luck too far today... $filename(csv,utf-16)|Album|Genre| $loop(%album%)|%album%|$meta_sep(genre,\\)| $loopend() I was hoping this would produce a single line per album but its giving all tracks for the same album!! |
Feb 22 2012, 13:40
Post
#10
Maybe I am pushing my luck too far today... $filename(csv,utf-16)|Album|Genre| $loop(%album%)|%album%|$meta_sep(genre,\\)| $loopend() I was hoping this would produce a single line per album but its giving all tracks for the same album!! Looks like I forgot something in my examples. $loop(%album%) only sorts your files by %album% $loop(%album%,1) sorts your files by %album% and does only write one entrie per %album%. So try this: $filename(csv,utf-16)|Album|Genre| $loop(%album%,1)|%album%|$meta_sep(genre,\\)| $loopend() |
Feb 22 2012, 13:54
Post
#11
Looks like I forgot something in my examples. $loop(%album%) only sorts your files by %album% $loop(%album%,1) sorts your files by %album% and does only write one entrie per %album%. So try this: $filename(csv,utf-16)|Album|Genre| $loop(%album%,1)|%album%|$meta_sep(genre,\\)| $loopend() yup, that was it. I learnt a lot quickly today thanks to your suggestions. Thanks, much appreciated |
Lo-Fi Version | Time is now: 19th May 2013 - 20:13 |
