Mar 11 2012, 03:02
Post
#1
Member Group: Members Posts: 3 Joined: 11-March 12 Member No.: 16173 Mp3tag Version: 2.49b |
Hi;
I´m new at this forum. Sorry for my bad english. Well, I would like to know what is the way to separate Artist name and Music name that are toguether inside the FILENAME field. They are separated by "-" character. In fact I need to move the artist name to the correct field. I´m sending one example; 09 - Henrique Cazes - With A Little Help From My Friends I need to move Henrique Cazes to artist field and to delete "- " from the filename. I do not understand very well about scripts and actions. I hope someone can help me with the procedure. Thanks Jaaf |
Mar 11 2012, 03:44
Post
#2
![]() Member Group: Full Members Posts: 404 Joined: 3-December 10 From: Ireland Member No.: 13334 Mp3tag Version: 2.54 |
Well, I would like to know what is the way to separate Artist name and Music name that are toguether inside the FILENAME field. They are separated by "-" character. In fact I need to move the artist name to the correct field. I´m sending one example; 09 - Henrique Cazes - With A Little Help From My Friends I need to move Henrique Cazes to artist field and to delete "- " from the filename. Menu>Convert>Filename - Tag. (Alt + 2) Then use mask: %dummy% - %artist% - %dummy% Afterwards use the following: Action type: Replace Field: _FILENAME Original: '- ' Replace with: BLANK [ ] only as whole word [ ] case-sensitive comparison This post has been edited by stevehero: Mar 11 2012, 03:45 -------------------- I ♥ singing Dubstep ♪♫WOOB WOOB WOOB WOOB UBB OHMOMOMO DROP WOOOOOOB WOOB WOOB WOOB WUB WUB WUB WUB WUB WUB WUB WUB MOMOMO WOOB WOOB♫♪
Mar 11 2012, 07:14
Post
#3
![]() Member Group: Full Members Posts: 4129 Joined: 26-May 06 From: Wuppertal, Germany, Planet Earth Member No.: 3194 Mp3tag Version: 2.54 |
... Well, I would like to know what is the way to separate Artist name and Music name that are toguether inside the FILENAME field. They are separated by "-" character. In fact I need to move the artist name to the correct field. I´m sending one example; 09 - Henrique Cazes - With A Little Help From My Friends I need to move Henrique Cazes to artist field and to delete "- " from the filename. ... See following pictures how to disassemble the filename using the dialog "Mp3tag/Convert/Filename - Tag" ... See following picture how to assemble the filename using the dialog "Mp3tag/Convert/Tag - Filename" ... I want to mention that the parts are not separated by the character "-" (<hyphen>). In the given example file name the parts are separated by the " - " string (<space><hyphen><space>). DD.20120311.0722.CET This post has been edited by DetlevD: Mar 11 2012, 07:23 -------------------- * Beyond that, don't ask, when you don't know what to do with the answer. *
♥ home is where the heart is ♥ |
Mar 11 2012, 14:54
Post
#4
Menu>Convert>Filename - Tag. (Alt + 2) Then use mask: %dummy% - %artist% - %dummy% Afterwards use the following: Action type: Replace Field: _FILENAME Original: '- ' Replace with: BLANK [ ] only as whole word [ ] case-sensitive comparison So many thanks for this help. It´s exactally what I need. Regards |
Mar 11 2012, 15:03
Post
#5
See following pictures how to disassemble the filename using the dialog "Mp3tag/Convert/Filename - Tag" ... See following picture how to assemble the filename using the dialog "Mp3tag/Convert/Tag - Filename" ... I want to mention that the parts are not separated by the character "-" (<hyphen>). In the given example file name the parts are separated by the " - " string (<space><hyphen><space>). DD.20120311.0722.CET What a wonderfull explanation! Thanks. I´ll try to learn a little bit more about this great MP3 tool. BTW, are there some scripts to get rid of all those characters that are not standard, and do not appear correctlly on display, just like accents an others Example: ~ ^ ´ ` etc? Maybe another topic about this is already posted. Best regards |
Lo-Fi Version | Time is now: 19th May 2013 - 01:53 |
