IPB
> [X] Problem with Mp3tag reading tags of mp3 files, When a read a mp3 file, the title, artist, album tags don't appear
chchbrs
post Mar 25 2012, 17:22
Post #1
Member
Group: Members
Mp3tag Version: 2.50
Hello.
I've used mp3tag for 5 years ago, and I've never happened this. When a read a mp3 file, the tag file says IDE3v1, IDEv2.3, APE, but the title, artist, track, album fields appear empty. I try filling the fields again, but it doesn't appear. The only solution is to unistall and reinstall the program, and it works fine, but the problem persist. How can I resolve this??? thanks!!!
Go to the top of the page
+Quote Post
ohrenkino
post Mar 25 2012, 17:51
Post #2
Member
Group: Full Members
Mp3tag Version: 2.55a
ZITAT(chchbrs @ Mar 25 2012, 17:22) *
... read a mp3 file, the tag file says ... APE...
I guess the problem are the APE tags.
Go to Tools>Options>MPEG and switch off reading and writing APE but switch on deleting APE tags.
APE tags overrule MP3 tags so if there is nothing in the APE tags then you don't see anything in MP3tag.
To get rid of the the APE tags, select the files in the files list, then cut the tags with the function from the context menu and paste then immediately afterwards (use small portions of files so that if the computer reboots between cutting an pasting and the data in the clipboard is lost, not too much damage is done).
You find the files with APE tags if you apply the filter
%_tag% HAS APE.
42 - wie war die Frage / what was the question / comment était la question
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 21st May 2013 - 15:51
