May 7 2012, 00:41
Post
#1
Member Group: Full Members Posts: 7 Joined: 7-May 12 Member No.: 16418 Mp3tag Version: 2.50 |
I've attached
titlecase.zip ( 2.36K )
Number of downloads: 30the Python script I was using with MusicBrainz Picard. The beauty of this plugin was that it followed the New York Times Manual of Style in deciding what to make lowercase or not. After exploring this and a script I found online at http://liquidparallax.com/2007/10/19/mp3ta...ollection/#titl I've modified it and created a version that's in the same spirit of the original plugin. For the most part you can look in the attached
Title_Case__It__s_a_Smart_Conversion_.zip ( 426bytes )
Number of downloads: 21and you will find the lines where they specify lowercase characters to be nearly identical. So I just copied over the one from the Python script and replaced the one in the mp3tag script. It works fine and does what I was hoping for :-) Thanks everyone for reading this thread, I got lucky and found a script I could adapt. This was my modification if you want to have a look
Title_Case__New_York_Times_Manual_of_Style_.zip ( 490bytes )
Number of downloads: 27This post has been edited by dreamslides: May 8 2012, 01:03
Attached File(s)
May 7 2012, 06:51
Post
#2
![]() Member Group: Full Members Posts: 3140 Joined: 9-December 09 From: Norddeutschland / Northern Germany Member No.: 11458 Mp3tag Version: 2.55a |
Hey can you guys take a look at this perl script? I have no programming skills and thought this may not be so difficult for one of you to assist me on, the script would be useful to anyone on here as well if you can help :S Thanks everyone! You might want to have a look at this thread - as this uses MP3tag resources: http://forums.mp3tag.de/index.php?showtopic=13185 This post has been edited by dano: May 7 2012, 08:14 -------------------- 42 - wie war die Frage / what was the question / comment était la question
May 7 2012, 19:27
Post
#3
![]() Member Group: Full Members Posts: 4129 Joined: 26-May 06 From: Wuppertal, Germany, Planet Earth Member No.: 3194 Mp3tag Version: 2.54 |
Hey can you guys take a look at this perl script? I'd like to have the same thing for use in mp3tag. ... I want to mention, that you have offered not a Perl script, but a Python script! What have you tried so far on your transcription of the "New York Times Manual of Style" rules into Mp3tag Scripting language and where did you realize problems? DD.20120507.2022.CEST This post has been edited by DetlevD: May 7 2012, 19:30 -------------------- * Beyond that, don't ask, when you don't know what to do with the answer. *
♥ home is where the heart is ♥ |
May 7 2012, 20:30
Post
#4
See above
This post has been edited by dreamslides: May 8 2012, 00:21
Attached File(s)
Fix_AccurateRipResult.mta ( 543bytes )
Case_conversion.mta ( 33bytes )
New_York_Times_Manual_of_Style.mta ( 694bytes )
Number of downloads: 20 |
May 7 2012, 20:56
Post
#5
... I upload the files here ... Please attach the mta files (maybe zipped) to your forum post, not elsewhere on the internet. Do I understand it right that you got all the mta rules running without any problem? I would avoid to use the pseudo tagfield _ALL and use instead _TAG. DD.20120507.2148.CEST This post has been edited by DetlevD: May 7 2012, 20:57 -------------------- * Beyond that, don't ask, when you don't know what to do with the answer. *
May 7 2012, 22:49
Post
#6
See above
This post has been edited by dreamslides: May 8 2012, 00:21 |
Lo-Fi Version | Time is now: 19th May 2013 - 02:31 |
