Jul 20 2012, 22:26
Post
#1
Member Group: Full Members Posts: 28 Joined: 23-January 11 Member No.: 13673 Mp3tag Version: 2.49a |
Hi
I'm user of mp3tag for some years now, & something bugs me when managing tags using extended tag panel. I use "Del" key to remove the value but occasionally I press "Del" key over wrong tag fields & then have to cancel the panel & do what I done all over again. I could be useful to have a button to change the value to <keep> with a keyboard stroke like "Insert" & would save me hours of my time redoing or manually typing the <keep> value. It could be named as restore to default or revert or what so ever... I actually wanted the tag panel to show every value the selected mp3 files have like the menu tag fields. but that <keep> button is just enough for me. Thanks for your time & effort... |
Jul 21 2012, 14:17
Post
#2
![]() Member Group: Full Members Posts: 4129 Joined: 26-May 06 From: Wuppertal, Germany, Planet Earth Member No.: 3194 Mp3tag Version: 2.54 |
... when managing tags using extended tag panel ... occasionally I press "Del" key over wrong tag fields & then have to cancel the panel & do what I done all over again. I could be useful to have a button to change the value to <keep> with a keyboard stroke like "Insert" & would save me hours of my time redoing or manually typing the <keep> value. It could be named as restore to default or revert or what so ever ... The proposal offers a good suggestion, but needs some more detailed view. I am speaking now about the dialog "Extended Tags..." Once a single-value tag-field name is selected for deletion, using the [Del] key, it will be marked with the label <blank> for later physical deletion after pressing [OK]. Once a multi-value tag-field name is selected for deletion using the [Del] key, this single item will be removed from the list of tag-field names. Only when all multi-value items are manually removed, then the remaining 'root' tag-field name will be marked with the label <blank>. It would be handy when a key combination like [Shift]+[Del] can undo the last [Del] processed step and restore the situation as it was before, independently for each tag-field name respectively for each multi-value tag-field sibling. Thus an user can immediately correct the last entry error and must not start all over again. DD.20120721.1515.CEST This post has been edited by DetlevD: Jul 21 2012, 17:59 -------------------- * Beyond that, don't ask, when you don't know what to do with the answer. *
♥ home is where the heart is ♥ |
Jul 21 2012, 18:48
Post
#3
Thanks DetlevD for your support... looking forward to see this in next version
Lo-Fi Version | Time is now: 25th May 2013 - 09:10 |
