IPB
> Notice!
> RegExp Help, Capitalize a letter after ( [ " ' when ( [ " ' precede
niche99
post Jul 28 2012, 04:40
Post #1
Member
Group: Members
Mp3tag Version: 2.52
I have tried the following with no success
regexp: (\s\'.)
replace: \U$0
and replaced the red character with [, " and ' with no consistent success.
For example the above regexp produces this:
The 'torchum' Never Stops -> The 'Torchum' Never Stops <- which I want.
The Massive Improve'lence -> The Massive Improve'Lence <- which I don't want.
Any help would be appreciated.
Regards,
niche99
Go to the top of the page
+Quote Post
stevehero
post Jul 28 2012, 11:20
Post #2
Member
Group: Full Members
Mp3tag Version: 2.84
QUOTE (niche99 @ Jul 28 2012, 04:40) *
regexp: (\s\'.)
replace: \U$0
Your action could not possibly work as \U in the replace is not how you go about doing this. It only works to find a non-upper case character anyway.
See http://help.mp3tag.de/options_format.html#regexp
For your problem try this.
Begin Action Group _Script Test#TEST
Action #1
Actiontype 4: Replace with regular expression
Field ______________: TITLE
Regular expression _: \s+'(.)
Replace matches with:
$upper($1)
[_] Case sensitive comparison
End Action Group _Script Test#TEST (1 Action)
This finds:
\s+ \s Space character unlimited times +
' The ' character
(.) Start capture ( with . representing any character and ) closing the capture
Replaces:
$upper Converts
($1) Captured like above
See http://help.mp3tag.de/main_scripting.html#general for more info.
This post has been edited by stevehero: Jul 28 2012, 11:31
+Quote Post
DetlevD
post Jul 28 2012, 12:10
Post #3
Member
Group: Full Members
Mp3tag Version: 2.84e
QUOTE (niche99 @ Jul 28 2012, 05:40) *
... The 'torchum' Never Stops -> The 'Torchum' Never Stops <- which I want.
The Massive Improve'lence -> The Massive Improve'Lence <- which I don't want. ...
The problem seems to be the punctuation mark "Apostroph", which is a word delimiter.
Therefore it is not so easy to code a lookbehind or lookahead.
But there is a workaround, which can help quickly.
For the capitalization use the function $caps2() and subsequently do the trick using the function $regexp().
$regexp($caps2(%FIELD%,' (["'),'(\s\x27)(.)','$1\u$2')
... or ...
$regexp($caps2(%FIELD%,' (["'),'\s\x27.','\U$0')
... or ...
$regexp(%FIELD%,'(^|\x20\x27|[[(\x20\x22])(.)','$1\u$2')
Apply the above expressions by action "Format value" or by converter "Tag - Tag".
If you want to apply the capitalization rule to all tag-fields at once, then use ...
Field ______________: _TAG
Regular expression _: (^|\x20\x27|[[(\x20\x22])(.)
Replace matches with: $1\u$2
Examples
the 'torchum' never stops -> The 'Torchum' Never Stops
the massive improve'lence -> The Massive Improve'lence
aaa bbb(ccc[ddd"eee 'fff -> Aaa Bbb(Ccc[Ddd"Eee 'Fff
aaa bbb(ccc[ddd"eee'fff 'ggg -> Aaa Bbb(Ccc[Ddd"Eee'fff 'Ggg
See also ...
http://forums.mp3tag.de/index.php?showtopi...ost&p=23265
DD.20120728.1314.CEST
Edit.DD.20120729.0842.CEST
This post has been edited by DetlevD: Jul 29 2012, 07:46
+Quote Post
stevehero
post Jul 28 2012, 18:06
Post #4
Member
Group: Full Members
QUOTE (DetlevD @ Jul 28 2012, 12:10) *
The same not be done with:
Action #1
Regular expression _: (\B|^)(\(|\[|"|')(.)
Replace matches with: $1$2$upper($3)
Resulting in:
(the [torchum' "never 'stops blank(the[torchum"never'stops >>>> (The [Torchum' "Never 'Stops blank(the[torchum"never'stops
by breaking up the different parts like not a word boundary OR start of string / (["'' / any one character to capture as $1, $2 & $3 (changed to upper-case) it seems to work. If you don't separate them like this you get unwanted results.
Plus one thing with using the action 'replace with regular expression' you can affect _TAG (All tags) like the example above whereas with the format action you can't.
Anybody know why mp3tag doesn't pick up the start of the string '(the [torchum' "never...' by using the \B. My fix was to put in a '|^' to fix the problem.
This post has been edited by stevehero: Jul 28 2012, 18:13
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 22nd October 2017 - 14:54
