Jul 31 2012, 10:40
Post
#1
Member Group: Full Members Posts: 11 Joined: 10-January 11 Member No.: 13580 Mp3tag Version: 2.51 |
Is it possible to use the filter to list all non blank Duplicates in the Lyrics tag?
Thanks |
Jul 31 2012, 10:47
Post
#2
![]() Member Group: Full Members Posts: 3221 Joined: 9-December 09 From: Norddeutschland / Northern Germany Member No.: 11458 Mp3tag Version: 2.55a |
Is it possible to use the filter to list all non blank Duplicates in the Lyrics tag? Thanks If you mean a comparison between at least two files then the answer is "no" as mp3tag only looks at one file at the time and does not compare any two files. -------------------- 42 - wie war die Frage / what was the question / comment était la question
Jul 31 2012, 11:16
Post
#3
Jul 31 2012, 11:53
Post
#4
Wasn't very satisfying, right?
But honestly: all you can do is setup a column for the field that you want to compare and sort by it. So you have at least those close to each other that start with the same words. -------------------- 42 - wie war die Frage / what was the question / comment était la question
Lo-Fi Version | Time is now: 18th June 2013 - 22:58 |
