IPB
4 Pages V   1 2 3 > »
> Web Source Framework Discussion
mll
post Feb 7 2005, 22:18
Post #1
Member
Group: Full Members
Mp3tag Version: 2.37h
VERY nice innovation ! And works for me smile.gif Just hope that the guys at AMG et al. won't find it to be some violation of some kind...
Aren't AMG and artistdirect files supposed to be installed by 2.28b ? At least that's what this seems to intend.
Also, a quick way to get to the folder :
Win+R, then type
QUOTE
%appdata%\mp3tag\data\sources
MLL
Go to the top of the page
+Quote Post
Digitaldesi
post Feb 8 2005, 05:17
Post #2
Member
Group: Full Members
Mp3tag Version: 2.54
First of all mp3tag is the best mp3 tag software (compared to other commercial taggers) I've ever used. Now that it can get data from other web sources (including allmusic.com) just made it even better. I use wmp to rip my cd's and wmp uses allmusic data tags. Thanks Florian and various developers for making this great program.
I'm using amg.src, but it doesn't get all the data that is provided by the site. For example the composer field, publisher etc. Will these be added in the later versions or no.
Thanks again.
+Quote Post
Florian
post Feb 9 2005, 18:54
Post #3
Developer
Group: Admin
Mp3tag Version: 2.84d
Thanks for the nice feedback!
QUOTE (Digitaldesi @ Feb 8 2005, 05:17 AM)
Since this web source definition file is not my own work, we have to see what the author is planning smile.gif
+Quote Post
willmcelwain
post Feb 18 2005, 01:43
Post #4
Member
Group: Full Members
Mp3tag Version: 2.46c
First of all, I have to thank Florian for finally making a wonderful tagger (for free no less) that lets you customize web sources like this. The only other tagger with this kind of functionality is The GodFather, but their scripting is much more complex. I've spent a couple of hours on the following scripts, so I hope you find them useful:
Artist Direct
The above artistdirect.src wasn't grabbing track names correctly for me, so here's a (hopefully) fixed version.
Musicbrainz
FINALLY! An alternative to the Musicbrainz Tagger! I do belive this addon will make Mp3tag the first tagger to support Musicbrainz lookups. I think Musicbrainz has the most accurate database out there (even better than AMG), and I've been dying for Musicbrainz support (from anyone) since I first discovered it. It may not work perfectly yet, but this script should be a good start.
Possible Problems
1) This script searches by album name. If the album name is unique, Musicbrainz takes you directly to the album page (w/track listings) instead of letting you select that album. This causes Mp3tag to report an error. Am I missing something? Is there a way to jump to the [ParserScriptAlbum] section if this happens?
2) Right now, the year that is grabbed is the first one listed at the bottom of the page. If there happen to be multiple releases (say in different countries), then it could grab the wrong year. I haven't found an occurrence of this yet though.
3) Musicbrainz doesn't list any genre info, so you'll have to enter that in manually.
Suggested Improvements for Mp3tag
Web Sources
-) In the scripting, it'd be nice if there was a generic whitespace character (like regex), so instead of matching exactly "*tab*tab*tab*<tr>", you could match "\s<tr>" instead.
-) It might be nice to rearrange the [IndexFormat] headers (in the GUI), so maybe you could have a [IndexFormatDisplay] variable that could be set to say "%artist%|%album%" (no %_url% needed since it's not in the GUI).
-) Mp3tag should automatically replace all special characters (like &amp;, &#[ASCII number];, etc.) in artist/album/track names before displaying them to the user. I don't know if this already happens before tagging or not, but it should happen before they're listed in the dialogs ("Adjust tag-information", etc.).
-) In the "Adjust tag-information" dialog, you can edit the info downloaded from a web source (say a track name), but it'd be nice to have either a text field or additional dialog that could let you edit the artist, album, year, and genre for *all* the tracks, instead of having to do that on a track-by-track basis.
-) When a user clicks OK on the "Adjust tag-information" dialog, it might instead be helpful to present the user with a Before and After view, kind of like MP3/Tag Studio's preview feature. I know Mp3tag has a "preview" feature for file renaming, but instead of a text file, it should be a separate window, and it should be used to preview tagging too (again, see how MP3/Tag Studio does it). Also, you could have 4 checkboxes in that window: "Rename Files", "Rename Directory" (see below), "Save Cover Art" and "Create Playlist".
General
-) There should be a feature to rename the current directory according to a certain format (say "%artist% - %year% - %album%").
-) Question: when a playlist is created (via "File->Playlist (all files)"), does it sort the files by track # first?
I'm sure I'll have more suggestions in the coming days, but that's all for now.
Thanks again for the excellent program!
-Will
Attached File(s)
+Quote Post
Florian
post Feb 18 2005, 21:44
Post #5
Developer
Group: Admin
Will,
first of all, thank you very much for the new web sources and your long feedback! Your support is very much appreciated! I'm very busy at the moment with university, so I may not have much time...
One quick question: can you tell me an album where the current artistdirect web source fails. I'm just curious, because no user has reported any issues till now.
Thanks!
Best regards,
~ Florian
+Quote Post
willmcelwain
post Feb 18 2005, 22:33
Post #6
Member
Group: Full Members
It didn't work for me on "3 Doors Down - Seventeen Days" (when searching for "Seventeen Days"). It'll find the album, but on the track listings dialog, it says "<Error>" in the first track field. The original script works on all of my other albums so far, so I don't know why that specific album would give it problems.
Will
+Quote Post
mll
post Mar 7 2005, 15:50
Post #7
Member
Group: Full Members
EDIT: apparently, they make it possible to make third-party client plugins. That would be cleaner I guess. Any chance to be something like it anytime ?
+Quote Post
Florian
post Mar 7 2005, 17:38
Post #8
Developer
Group: Admin
QUOTE (mll @ Mar 7 2005, 03:50 PM)
Calculating the TRM identifier requires internal decoding to WAV, so a decoder for every file format supported would be necessary. This is currently a little bit too much work.
+Quote Post
A Weakling Child
post Mar 22 2005, 22:07
Post #9
Member
Group: Full Members
Mp3tag Version: 2.45a
is it possible to get more information from discogs.com? not only artist, album, year, genre, title & track number.
if yes, then how?
thanks in advance.
EDIT: and you can't save cover. it's not showing.
+Quote Post
Florian
post Mar 23 2005, 13:27
Post #10
Developer
Group: Admin
QUOTE
if yes, then how?
I don't know which additional information you're looking for. Can you give an example for information available at the discogs.com website?
QUOTE
You can. But only if the album page on discogs.com shows a cover.
+Quote Post
A Weakling Child
post Mar 23 2005, 22:56
Post #11
Member
Group: Full Members
QUOTE
QUOTE
it is there. and when i press Preview i can see it on the page opened in browser. but when i choose the album & press OK, i see only track information, cover is blank & the button to save it is grey. tested with the following release: http://www.discogs.com/release/3193.
thanks for quick response & sorry for bugging.
+Quote Post
Florian
post Mar 24 2005, 09:47
Post #12
Developer
Group: Admin
QUOTE (A Weakling Child @ Mar 23 2005, 10:56 PM)
Yes, it's possible by modifying the web source description file. Maybe I'll make an extended version of discogs.src.
QUOTE
I think you're using an old version of the web source. Please get the latest one from here.
Best regards,
~ Florian
+Quote Post
A Weakling Child
post Mar 24 2005, 15:08
Post #13
Member
Group: Full Members
QUOTE
cool, thanks.
QUOTE
done that - no luck. cover is blank, button is grey.
i'm under proxy, but as long as everything else works properly, i don't think that it's the issue.
+Quote Post
Florian
post Mar 24 2005, 17:16
Post #14
Developer
Group: Admin
QUOTE (A Weakling Child @ Mar 24 2005, 03:08 PM)
That's the problem - I forgot to use the proxy for getting the cover art. I'll fix it to the next release.
Thanks for your feedback!
~ Florian
+Quote Post
A Weakling Child
post Mar 24 2005, 18:11
Post #15
Member
Group: Full Members
You are very welcome & thank you very much for your help!
+Quote Post
4 Pages V   1 2 3 > »
0 Members:
RSS Lo-Fi Version Time is now: 17th October 2017 - 14:03
