IPB
11 Pages V   1 2 3 > »
> [WS] Import lyrics from websites, web sources scripts
dano
post Jun 9 2005, 00:19
Post #1
Moderator
Group: Moderators
Mp3tag Version: 2.84c
Mp3tag v2.39 or higher required
Finds song texts and saves them to the UNSYNCEDLYRICS field (official ID3v2 field).
How do I install the script? / Wie installiere ich das Script?
Search for lyrics on different sites!
Note: Darklyrics only has songs from Metal bands and to use it properly you must select all files of an album and you'll get all songs at once.
Other scripts in this thread:
Lyriki & Lyricsmania
RapGenius
This post has been edited by dano: Sep 12 2014, 21:50
Attached File(s)
Attached File  Lyrics_lyricWiki_04.zip ( 828bytes ) Number of downloads: 7546
Attached File  Lyrics_Magistrix.de_03.zip ( 1.01K ) Number of downloads: 9138
Attached File  Lyrics_metrolyrics_02.zip ( 736bytes ) Number of downloads: 10955
Attached File  Lyrics_SongMeanings_02.zip ( 687bytes ) Number of downloads: 9565
Attached File  Lyrics_Darklyrics_02.zip ( 797bytes ) Number of downloads: 10815
Go to the top of the page
+Quote Post
freekey
post Aug 24 2005, 05:25
Post #2
Member
Group: Full Members
Mp3tag Version: 2.46a
can anyone please tell me what lyricsforall.zip is all about?
Is that an add-on to mp3tag?
Thank you.
+Quote Post
dano
post Aug 24 2005, 09:21
Post #3
Moderator
Group: Moderators
It's a web source script to save lyrics in the ID3v2 tag.
+Quote Post
ulysses
post Oct 18 2005, 19:00
Post #4
Member
Group: Full Members
Mp3tag Version: 2.33
Thanks Dano. Works great.
A few questions:
- When viewing these files with iTunes, the lyrics show up in the lyrics tab but most of the lines begin with an HTML line-break tag (br). What can be done to prevent this?
- Is there a column I can add to Mp3tag to display whether it has lyrics in the tag?
- Is there a way to merge the lyrics-downloader with the line-breaks utility?
+Quote Post
dano
post Oct 18 2005, 19:34
Post #5
Moderator
Group: Moderators
QUOTE
Do you have the latest version of the linebreak action and do you apply it after lyrics have been saved?
If all that does not work give me examples of songs.
QUOTE
You can add a column with the value $if(%UNSYNCEDLYRICS%,x,)
QUOTE
Not at the moment.
+Quote Post
ulysses
post Oct 18 2005, 20:18
Post #6
Member
Group: Full Members
QUOTE (dano @ Oct 18 2005, 14:34)
Oops. It worked without the extra breaks after I ticked read & write ID3v2 in options.
QUOTE
Thanks Dano!
+Quote Post
ulysses
post Oct 19 2005, 21:38
Post #7
Member
Group: Full Members
It happened again.
QUOTE
Yes.
QUOTE
Yes.
QUOTE
How do the lyrics look in Mp3tag? Check with ALT+T
They have the HTML break (br) or (br /) tags.
QUOTE
Tears for Fears - Everybody Wants to Rule the World
Hall & Oates - Out of Touch
Though it did work on some other songs.
+Quote Post
dano
post Oct 19 2005, 22:35
Post #8
Moderator
Group: Moderators
Ok, I didn't know they also use <br /> sometimes.
I included this now and the action now also changes the language description from undefined (XXX: ) to english (eng: )
I think if the language is not set to english, itunes rewrites the lyrics when saving tags.
+Quote Post
ulysses
post Oct 19 2005, 22:52
Post #9
Member
Group: Full Members
Thanks Dano. It now works with every song I try.
Now, if there was only a way to make this work on multiple selected files.
+Quote Post
dano
post Nov 18 2005, 13:47
Post #10
Moderator
Group: Moderators
Update!
+Quote Post
ulysses
post Nov 18 2005, 15:13
Post #11
Member
Group: Full Members
Awesome. Thanks Dano.
+Quote Post
Sammy20
post Dec 3 2005, 09:32
Post #12
Member
Group: Full Members
Mp3tag Version: 2.39d
Is there are way to make this script work on multiple files? When I select multiple files it just saves the same tag from the first title search.
For the song 'New Order - Whos Joe' no results come up. Why is that? I tried
Who's joe?
whos joe
No result.
+Quote Post
dano
post Dec 3 2005, 11:10
Post #13
Moderator
Group: Moderators
1) It's not possible.
2) If the website doesn't return results for you entries, it's no surprise it doesn't work in Mp3tag..
How about who's joe
+Quote Post
dano
post May 19 2006, 14:25
Post #14
Moderator
Group: Moderators
Added Darklyrics.com for the (Heavy) Metal fans. It works different from the other scripts, it tags all songs from one album at once.
You also need album and artist tags filled (or know them).
+Quote Post
SquallLeonhart38
post May 19 2006, 14:52
Post #15
Member
Group: Full Members
Mp3tag Version: 2.40c
Now it's even easier to tag metal songs.
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 17th January 2018 - 21:09
