IPB
2 Pages V   1 2 >
> [F] Installer is broken
Illuminator
post Feb 19 2017, 07:30
Post #1
Member
Group: Full Members
Mp3tag Version: 2.77
I just download latest MP3tag (2.81). When I try to install it, I see the broken text in the installer.
OS: Windows 10 Pro 64 Bits
This post has been edited by Illuminator: Feb 19 2017, 07:31
Go to the top of the page
+Quote Post
Florian
post Feb 19 2017, 09:47
Post #2
Developer
Group: Admin
Mp3tag Version: 2.85k
From your screenshot I can see that you're using Windows in your specific locale. I'm not able to read this language and to decide which parts are correct and which are not.
Can you please explain a little what you mean by "broken"?
Kind regards
– Florian
+Quote Post
Illuminator
post Feb 19 2017, 11:28
Post #3
Member
Group: Full Members
QUOTE (Florian @ Feb 19 2017, 15:47) *
Kind regards
– Florian
Installer shows with unreadable text.
It isn't English. It contains some character in my language but it is not readable word.
It's just random character.
This post has been edited by Illuminator: Feb 19 2017, 11:35
+Quote Post
Mike_nl
post Feb 20 2017, 08:13
Post #4
Member
Group: Full Members
Mp3tag Version: 2.83f
Florian,
I have marked (only) a couple of the problem letters for you so you can see what is wrong.
Florian, which installer do you use ? Inosetup / Nullsoft ?
My guess that the OP has some DLL's missing on his / her PC.
This post has been edited by Mike_nl: Feb 20 2017, 08:14
Have fun while it lasts ;)
+Quote Post
Illuminator
post Feb 20 2017, 08:27
Post #5
Member
Group: Full Members
QUOTE (Mike_nl @ Feb 20 2017, 14:13) *
Florian,
Almost all text is unreadable (all text that contain my language characters) except English text.
I downloaded the installer from http://www.mp3tag.de/en/download.html
Here is file properties:
File Hash (MD5):
CODE
BE65707AF460F5D95BB9789E2E48D0C7
This post has been edited by Illuminator: Feb 20 2017, 08:28
+Quote Post
Mike_nl
post Feb 20 2017, 11:40
Post #6
Member
Group: Full Members
^ I understand as I live in Thailand and my wife is THAI and she also can't understand it.
I just pointed SOME errors out for Florian as he can't read Thai.
PLEASE Let's wait what Florian has to say about this, maybe it's a problem with the installer and maybe another error.!
Edit: But (ignoring the (unreadable) Characters) does the Installer works ? Or ????
This post has been edited by Mike_nl: Feb 20 2017, 11:45
+Quote Post
Illuminator
post Feb 20 2017, 11:57
Post #7
Member
Group: Full Members
QUOTE (Mike_nl @ Feb 20 2017, 17:40) *
Thank you.
But I will not continue installing because I can't read these text. I don't want to make any mistake while installing.
OK. I'll wait.
This post has been edited by Illuminator: Feb 20 2017, 12:00
+Quote Post
Florian
post Feb 20 2017, 13:17
Post #8
Developer
Group: Admin
QUOTE (Mike_nl @ Feb 20 2017, 08:13) *
Thanks, Mike. I'm using NSIS and switched to v3.01 from v2.53 with this release (and the betas which led to v2.81).
I've checked the setup and I can't see any prominent issues. Maybe the Thai language file of NSIS itself is broken?
https://sourceforge.net/p/nsis/code/HEAD/tr...0files/Thai.nlf
https://sourceforge.net/p/nsis/code/HEAD/tr...0files/Thai.nsh
Kind regards
– Florian
+Quote Post
Mike_nl
post Feb 20 2017, 14:05
Post #9
Member
Group: Full Members
Thanks Florian.
As I can't read Thai that well (only at kindergarten grade 2 biggrin.gif ) it's a difficult problem.
My advice to Illuminator would be.
Have a Search on Forums like Pantip (in THAI) etc to see if there are known errors with Nullsoft (NSIS) and Thai Language in combination with Windows 10.
I will also have a look, but as my Thai language skills are limited I doubt I can find an answer but if I do, I will report back.
+Quote Post
Mike_nl
post Feb 21 2017, 07:22
Post #10
Member
Group: Full Members
Florian,
read this (maybe it makes sense to you)
QUOTE
I am using "SetFont "Arial" 10", in my installer. But as the Thai language does not support "Arial, times, verdana ,...", so I want to disable the font setting in case of Thai language selection.
Can anybody tell me, how to disable the font setting in case of "Thai" language selection, inside a function.
Regards
Venu
kichik
18th October 2004 18:37 UTC
SetFont has a /LANG= switch. Use it to define a font for every language but Thai.
Link: https://nsis-dev.github.io/NSIS-Forums/html/t-196558.html
And this
QUOTE
Since NSIS 2.26, the language selection dialog of Modern UI hides languages unsupported by the user's selected codepage by default. This prevents the user from selecting unsupported languages and getting garbage for text. The user can select another codepage in the Regional and Language Options control panel under the Advanced tab in the Language for non-Unicode programs box.
To revert to the old behavior and display all languages, no matter what the user will see when they're selected, use MUI_LANGDLL_ALLLANGUAGES.
From here: http://nsis.sourceforge.net/Why_does_the_l..._some_languages
This post has been edited by Mike_nl: Feb 21 2017, 07:26
+Quote Post
Illuminator
post Feb 22 2017, 12:41
Post #11
Member
Group: Full Members
QUOTE (Florian @ Feb 20 2017, 19:17) *
Kind regards
– Florian
These files are readable. I have no idea why installer is broken.
+Quote Post
Florian
post Mar 13 2017, 10:33
Post #12
Developer
Group: Admin
Can you please try the current Development Build Mp3tag v2.81a.
Kind regards
– Florian
+Quote Post
Illuminator
post Mar 13 2017, 11:26
Post #13
Member
Group: Full Members
QUOTE (Florian @ Mar 13 2017, 16:33) *
Kind regards
– Florian
This post has been edited by Illuminator: Mar 13 2017, 11:27
+Quote Post
Florian
post Mar 13 2017, 14:22
Post #14
Developer
Group: Admin
+Quote Post
Mike_nl
post Mar 14 2017, 11:33
Post #15
Member
Group: Full Members
QUOTE (Florian @ Mar 13 2017, 20:22) *
Florian,
I personally find this a very strange fix. Why ?
NSIS supports Thai (as you already linked to the Thai Language Files) but you default to English when the language is Not Supported, but Thai is supported by the Installer.
Thx
+Quote Post
2 Pages V   1 2 >
0 Members:
RSS Lo-Fi Version Time is now: 24th January 2018 - 02:50
