IPB
> [F] Installer shows unreadable text in wrong language
tag22
post Mar 13 2017, 00:04
Post #1
Member
Group: Members
Mp3tag Version: 2.81a
I have a Windows XP running in the Estonian locale (see the screenshots of regional and language settings in my Control Panel).
As shown in the next screenshot, Mp3tag v2.81 installer displays strange gibberish (probably some right-to-left language for which my system doesn't even have a proper font) instead of Estonian.
Unfortunately, installer provides no obvious way to choose the language manually, and there seems to be no command line switch to force it to English or at least something European. sad.gif
Go to the top of the page
+Quote Post
Mike_nl
post Mar 13 2017, 05:31
Post #2
Member
Group: Full Members
Mp3tag Version: 2.83f
Florian,
this bug is related to this one, where a user (Thai) has the same complaint.
https://forums.mp3tag.de/index.php?showtopic=22115
Have fun while it lasts ;)
+Quote Post
ohrenkino
post Mar 13 2017, 07:27
Post #3
Member
Group: Full Members
Mp3tag Version: 2.85h
QUOTE (tag22 @ Mar 13 2017, 00:04) *
I have a Windows XP running in the Estonian locale ...
The question is whether MP3tag still supports Windows XP ...
I remember that when I used MP3tag and XP that some system generated text boxes could not cope with special characters and showed squares instead.
+Quote Post
tag22
post Mar 13 2017, 07:30
Post #4
Member
Group: Members
Mike, it's not quite the same complaint. I think mine is rather different. In the other post you refer to, the installer has guessed the Thai locale correctly, but the font appears not to support it.
In my case, however, the installer fails to detect Estonian, and proceeds with some arbitrary language. I assume that Estonian is not included in the list of supported languages of this installer. But then it should either use English as the default (or German, it's up to the author) or offer the user to choose the preferred language.
+Quote Post
Florian
post Mar 13 2017, 08:22
Post #5
Developer
Group: Admin
QUOTE (ohrenkino @ Mar 13 2017, 07:27) *
This is not the question of this topic. According to the download page Windows XP SP3 is officially supported. If you notice any bugs on such a system which does not appear elsewhere, please report it in a separate topic.
Kind regards
– Florian
+Quote Post
Florian
post Mar 13 2017, 08:23
Post #6
Developer
Group: Admin
QUOTE (tag22 @ Mar 13 2017, 07:30) *
I'll try to investigate, thanks for reporting!
Kind regards
– Florian
+Quote Post
Florian
post Mar 13 2017, 10:33
Post #7
Developer
Group: Admin
Can you please try the current Development Build Mp3tag v2.81a.
Kind regards
– Florian
+Quote Post
tag22
post Mar 13 2017, 12:34
Post #8
Member
Group: Members
I've looked into this bug more closely and now it appears that Mike is correct: in fact, this is the same problem as mentioned in the referred post.
I've noticed that the text itself appears exactly the same in both cases (judging by the number of letters, repetitions and double-letters in the same locations), only character sets are different. After some experimenting with Google Translate and character encodings, I think the original text is in Arabic. (Because the last sentence should read "Click Next to continue.")
This means that Thai language was also not detected/supported by the installer. As the result in both cases, installer chose Arabic (perhaps because it is the first language in the list where language names are sorted alphabetically).
It seems like the original Arabic text the installer is trying to display is written in the Windows-1256 (Arabic) code page. Perhaps this would be the default code page on Arabic Windows PCs. However, because in my PC the default is the Windows-1257 (Baltic) code page, I see the gibberish pictured above. And the other customer (Illuminator, in the referred post) has the TIS-620 (Thai) character encoding set as default on their PC. So the characters appear different (Thai script), but in fact the text is completely unreadable because it is originally in Arabic.
To sum up: Arabic appears to be the language always chosen when the installer doesn't support the user's language.
+Quote Post
tag22
post Mar 13 2017, 12:46
Post #9
Member
Group: Members
Update: Yes, v2.81a fixes the problem: now installer uses English on my PC. Thanks! smile.gif
+Quote Post
Florian
post Mar 13 2017, 14:21
Post #10
Developer
Group: Admin
Great – thanks for confirming the fix!
And yes, Mike's pointer to the other topic made me come to the same conclusions – so thanks for that too smile.gif
Kind regards
– Florian
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 14th December 2017 - 06:58
