Aug 17 2005, 20:35
Post
#1
Member Group: Full Members Posts: 11 Joined: 17-August 05 Member No.: 2060 Mp3tag Version: 2.32 |
This is a great program, and one of a handfull of programs keeping me booting Windows on a regular basis. It beats Linux Easytag with a hammer.
Anyway, I'm wondering what the best way to remove a phrase that is in parenthesis from a Filename might be. I make my filename out of various tag elements like: %artist% - $num(%track%,2) - %title% - %album% However the Title often has some additional information in paranthesis that I don't want to be part of the Filename for two reasons: 1) I'm trying to keep file names less than 64 characters so I can make CDs to play on my portable MP3 CD player. 2) I understand CD-Rs do not appreciate parenthesis in any case. But I would like to keep the parenthetical information in the track Title so it displays when I play the song (my player displays Artist - Title). Otherwise I'd just do a Filename->Tag conversion and send the parenthetical expression to the Comment field, then rename the file with Tag->Filename. I have an inelegant way of dealing with this now. I simply manually edit the filenames in cases where not many files in an album have parenthetical clauses. In other cases I run a Replace action that converts "(" in to "- ", then I can wipe the expression from the Filename by running a Filename->Filename conversion using something like this: %1 - %2 - %3 - %4 - %5 %1 - %2 - %3 - %5 I searched through the English Support forum, but didn't find any suggestions. Leider, ich spreche Deutsch wie ein Eingeboren - aus Madagascar. Thanks, |
Aug 17 2005, 20:56
Post
#2
![]() Moderator Group: Full Members Posts: 2275 Joined: 15-June 03 From: Bad Herrenalb Member No.: 496 Mp3tag Version: 2.55a |
Do a RegEx replace on the filename using \s*\(.*\) as match and nothing as replace.
-------------------- There are 10 types of people in this world: those who understand binary, and those who don't.
Aug 18 2005, 05:05
Post
#3
Thanks, Sebastian, that did the trick. Now I just have to figure out why so I can learn a bit more about regular expressions.
Aug 18 2005, 08:41
Post
#4
QUOTE (Praxis @ Aug 18 2005, 06:05) Thanks, Sebastian, that did the trick. Now I just have to figure out why so I can learn a bit more about regular expressions. \s* matches any number of spaces. \( matches a bracket (the charecter has to be escaped or otherwise MP3Tag thinks that it's the beginning of a group). .* matches any number of characters \) matches a bracket. So basically, we are looking for spaces folowed by a bracket followed by characters followed by an ending bracket. All this is replaced by nothing. This post has been edited by Sebastian Mares: Aug 18 2005, 08:41 -------------------- There are 10 types of people in this world: those who understand binary, and those who don't.
Aug 18 2005, 18:15
Post
#5
QUOTE (Sebastian Mares @ Aug 18 2005, 00:41) \s* matches any number of spaces. \( matches a bracket (the charecter has to be escaped or otherwise MP3Tag thinks that it's the beginning of a group). .* matches any number of characters \) matches a bracket. So basically, we are looking for spaces folowed by a bracket followed by characters followed by an ending bracket. All this is replaced by nothing. Thanks again, a book on the wish list should be Amazon.deing its way to MP3Tag as I type (seemed easier than messing with PayPal, since I don't have an account). Hopefully I navigated the German menus properly. I fooled around with the RegEx stuff before I posted, but didn't quite get the syntax right on my own. I didn't use the '\s*' to find blank spaces and tried both '*' & '*.*' between the escaped paranthesis brackets, but it didn't seem to work properly. |
Lo-Fi Version | Time is now: 26th May 2013 - 02:25 |
