Oct 23 2005, 13:31
Post
#1
Member Group: Full Members Posts: 22 Joined: 23-October 05 Member No.: 2259 Mp3tag Version: 2.33a |
I am converting my music CD's to MP3 using EAC and LAME. I am editing/adding ID3 information using Mp3tag v 2.33a. The commandline for LAME defined in EAC is
-V 2 --vbr-new --add-id3v2 --pad-id3v2 --ta "%a" --tt "%t" --tl "%g" --ty "%y" --tn "%n" %s %d When opening the files in Mp3tag, I see the following in the left pane: Title; Artist; Album; Year; Track; Genre; Comment; Folder These seem to be ID3v1 fields. Looking at the file information in Winamp shows additional ID3v2 fields: Composer; Original artist; Copyright; URL; Encoded by My questions are: 1. How can I view (and edit) the ID3v2 information, that is being written into the mp3 files by LAME, by Mp3tag? 2. I would like to add the following information to each file: Movie; Composer; Lyricist; How do I do that and have Mp3tag show me these fields in the left pane? Background: Most of my CD's are compilations, so each file has a separate singer, movie, composer, lyricist in addition to having a common Album information. Presently, I'm adding this in the comment field. I would like to have them in their own ID3v2 fields, if possible. Thanks. Aloke |
Oct 23 2005, 13:45
Post
#2
![]() Moderator Group: Moderators Posts: 5506 Joined: 4-September 03 From: Germany Member No.: 201 Mp3tag Version: 2.55a |
Read this thread:
http://forums.mp3tag.de/index.php?showtopic=2600 -------------------- |
Oct 23 2005, 20:04
Post
#3
QUOTE (dano @ Oct 23 2005, 08:45) Thank you. It is a bit complicated for a beginner like me, but this is how I have set up the program: I added 2 columns: Name: Lyricist; Value: %lyricist%; Field: LYRICIST Name: Composer; Value: %Composer%; Field: COMPOSER For each song, I select the song and open the Tags (Alt-T) and add these two fields from the drop-down list. I could not find a suitable field for the name of the Movie, so I am using the Comment field for that. Am I doing this correctly? Is typing in text into the columns directly the same as the Alt-T and then entering the information there? Thanks. Aloke |
Oct 23 2005, 20:29
Post
#4
QUOTE Name: Lyricist; Value: %lyricist%; Field: LYRICIST Name: Composer; Value: %Composer%; Field: COMPOSER I think Field: should also be with % signs -> %lyricist% But your version seems to work, too. QUOTE Is typing in text into the columns directly the same as the Alt-T and then entering the information there? Yes. -------------------- |
Lo-Fi Version | Time is now: 23rd May 2013 - 00:21 |
