Oct 31 2005, 11:35
Post
#1
Member Group: Full Members Posts: 7 Joined: 31-October 05 Member No.: 2295 Mp3tag Version: 2.33d |
If anybody has any kind of problem with this web source, just email me. I hope you guys will put it to good use.
QUOTE History:
v1.01 -Fixed: Optimized the code a little bit. v1.00 -New: True various artists support. -New: Multiple/single search results work in tandem. -New: Will retrieve the biggest music cover Amazon has got to offer. -New: Use artist's other moniker if available. (** It would use "Masuda, Toshiro" instead of "増田俊郎".) -New: Added year column to search results window. This post has been edited by Cess Blue: Nov 1 2005, 22:56
Attached File(s)
Oct 31 2005, 11:46
Post
#2
![]() Developer Group: Admin Posts: 7621 Joined: 12-December 01 From: Germany, Dresden Member No.: 203 Mp3tag Version: 2.55a |
Thanks for your web source! Can you give a little bit more information about the differences to the other MusicBrainz web sources?
QUOTE (Cess Blue @ Oct 31 2005, 11:35) To Florian, I've run into a problem with a UNICODE problem. Try using my web source to search for "Last Exile OST 2". Look at the last 2 tracks. The names are gibberish... If you look at the website, it's fine. Do you know what the problem is? It's probably a problem with the default font you're using. Everything looks fine here: -------------------- |
Oct 31 2005, 13:24
Post
#3
QUOTE (Florian @ Oct 31 2005, 03:46) Thanks for your web source! Can you give a little bit more information about the differences to the other MusicBrainz web sources? It's probably a problem with the default font you're using. Everything looks fine here: By your request, I've added more information. Anyways, here's a screenshot of my window. See how it shows it at the top but at the bottom it's all gibberish (it's the same name) so I don't think it's a font problem... And it works in my web browser. Anymore thoughts on this problem? This post has been edited by Cess Blue: Oct 31 2005, 13:26 |
Oct 31 2005, 23:55
Post
#4
That's so weird. I removed the year tag from the last two files and the web source displays the right characters. But when I have the year tag filled, the web source gets that gibberish... Weird...
Nov 4 2005, 23:18
Post
#5
Sorry, but I've really no idea...
Lo-Fi Version | Time is now: 23rd May 2013 - 01:13 |
