IPB
> Notice!
> IDvX tags out of sync
john.leonard
post Oct 31 2005, 12:25
Post #1
Member
Group: Members
Mp3tag Version: 2.33
Has anyone created an "action" to resync field content between tag versions? I believe that I have a number of files with out-of-sync content of one or more ID3v1 and ID3v2 fields.
Should I simply delete the ID3v1 fields? or will this mess things up?
Is there a "best practice" for cleaning this up?
Thanks!
Go to the top of the page
+Quote Post
dano
post Oct 31 2005, 17:00
Post #2
Moderator
Group: Moderators
Mp3tag Version: 2.55a
You can sync by saving the tags again.
Note: Mp3tag displays only one tag type
For example, if you have the following options:
Read: ID3v1 and ID3v2
Write: ID3v1 and ID3v2
Now you have a file with both tag types, then what you see is the ID3v2 tag. If you save the tags now [Ctrl+S] the ID3v1 tag will get the same values as the ID3v2
+Quote Post
john.leonard
post Nov 1 2005, 09:43
Post #3
Member
Group: Members
Thanks, dano.
Is there a way to identify the files with out-of-sync tags?
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 19th June 2013 - 15:26
