IPB
> Notice!
> Global Command for the Comments Field
b8375629
post Dec 17 2005, 12:52
Post #1
Member
Group: Full Members
Mp3tag Version: 2.34a
Hello,
Is there any way I can globally copy the "Comments" field to ALL of the MP3 tracks within a given folder or directory, without having to hit Ctrl+C, Ctrl+V, Crtl+N for each and every track?
For instance, I want to copy an LP Matrix number, say "MCA 17794 LP" to ALL of the tracks in the directory, since they come from the same LP or CD. Is there any way to do that?
thanks...
Go to the top of the page
+Quote Post
Florian
post Dec 17 2005, 12:59
Post #2
Developer
Group: Admin
Mp3tag Version: 2.55a
Just select all files [Ctrl+A], set all fields on the tag panel to < keep > (will be done automatically) and enter "MCA 17794 LP" at the comment field.
Best regards,
~ Florian
+Quote Post
b8375629
post Dec 17 2005, 15:17
Post #3
Member
Group: Full Members
QUOTE (Florian @ Dec 17 2005, 07:59)
Best regards,
~ Florian
Hey, thanks for your response.
Yeah but the problem is I already have all the other fields filled with the info I want to keep after I converted all the tags from the filename.
How do I do that without erasing everything else with "< keep >"?
+Quote Post
dano
post Dec 17 2005, 15:30
Post #4
Moderator
Group: Moderators
Have you tried it? < keep > just means that the tag info is kept as it is when you save the tags, it doesn't overwrite anything.
+Quote Post
b8375629
post Dec 17 2005, 16:21
Post #5
Member
Group: Full Members
QUOTE (dano @ Dec 17 2005, 10:30)
I use Lamedrop 3.97beta to encode the WAVE files to MP3. Unfortunately, in the comments field, it's listed as "Encoded with Lamedrop 3.97beta" with each and every MP3. It automatically does this globally by default after I convert the filename to a tag.
The "< keep >" indicator is gone due to this.
Since I can't prevent Lamedrop from doing this (and it's a great little converter), I was wondering how I can globally change it AFTER I've converted all the other fields from filename to tag?
Or is there a way to default just this one field (comments field) before I convert the rest of the filename to a tag?
This post has been edited by b8375629: Dec 17 2005, 16:21
+Quote Post
Florian
post Dec 17 2005, 16:36
Post #6
Developer
Group: Admin
If you're using Mp3tag in another language than English you have to use the entry corresponding to "< keep >" from the drop-down list of the fields in the tag panel (e.g. "< beibehalten >" in german).
Best regards,
~ Florian
+Quote Post
b8375629
post Dec 17 2005, 16:50
Post #7
Member
Group: Full Members
QUOTE (Florian @ Dec 17 2005, 11:36)
Best regards,
~ Florian
Well I'm only using the English version.
So how would I globally change just this one field (the comments field) while perserving everything else after the filename to tag conversion?
Or is there no other way other than the way to do it, other than the way I mentioned in my original post?
Sorry if I'm not being clear on all this.
+Quote Post
Sebastian Mares
post Dec 17 2005, 18:30
Post #8
Moderator
Group: Full Members
QUOTE (b8375629 @ Dec 17 2005, 16:50)
Well, Florian explained it already - and the FAQs as well.
After running the Filename - Tag conversion, select all files, choose "< keep >" for Title, Artist, Album, etc. and for Comment, type in "MCA 17794 LP". After that, save the tags clicking on the mt_save.png icon from the toolbar.
There are 10 types of people in this world: those who understand binary, and those who don't.
+Quote Post
b8375629
post Dec 17 2005, 19:00
Post #9
Member
Group: Full Members
QUOTE (Sebastian Mares @ Dec 17 2005, 13:30)
That is EXACTLY what I'm looking for.
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 18th May 2013 - 06:23
