Jan 8 2006, 21:28
Post
#1
![]() Developer Group: Admin Posts: 7622 Joined: 12-December 01 From: Germany, Dresden Member No.: 203 Mp3tag Version: 2.55a |
1. I can't connect to the freedb server. What can I do?
2. How do I use a *.src file? 3. Profile folder This post has been edited by dano: Jan 10 2006, 23:13 -------------------- |
Jan 8 2006, 21:29
Post
#2
First of all, make sure that your firewall doesn't block access to the internet for Mp3tag. If you are sure, that HTTP access is allowed for Mp3tag, you can switch to another freedb mirror at Options > freedb > Server. If you have still problems with accessing freedb, increase the timeout value at Options > freedb > Server to 10 and try again. -------------------- |
Jan 10 2006, 22:55
Post
#3
![]() Moderator Group: Moderators Posts: 5525 Joined: 4-September 03 From: Germany Member No.: 201 Mp3tag Version: 2.55a |
Copy or move the *.src file to the profile folder %appdata%\Mp3tag\data\sources You can also just execute the openSourcesDirectory.bat file that automatically opens the correct folder. It either comes with the *.src file or can be downloaded from here. You can now use the script from the Tag Sources menu or from the Please visit the Web Sources Forum if you are interested in more scripts. This post has been edited by dano: Jan 11 2011, 22:31 -------------------- |
Jan 10 2006, 23:09
Post
#4
Profile folder
Location of the profile folder: Windows XP: C:\Documents and Settings\{user name}\Application Data\Mp3tag Windows Vista, 7, 8: C:\Users\{user name}\AppData\Roaming\Mp3tag The profile folder is normally a hidden folder. You can either activate "Show hidden files and folders" in the windows explorer options or use the direct path %appdata%\Mp3tag To use the direct path, you can either use the windows explorer and enter %appdata%\Mp3tag in the address bar or click Start > Run [Windows key+ R] and enter the path. The profile folder contains the following data:
This post has been edited by Florian: Apr 10 2013, 15:56 -------------------- |
Lo-Fi Version | Time is now: 20th June 2013 - 11:17 |
