IPB
> freedb web search update
dano
post Mar 21 2006, 21:38
Post #1
Moderator
Group: Moderators
Mp3tag Version: 2.55a
Since freedb has a new owner the web search is not available anymore.
It might come back but the date is unknown. (It needs to be rewritten).
As replacement you can try the freedb2 search or one of the many other sources.
(outdated, Attachement removed)
If you haven't already noticed, the freedb web search isn't working anymore.
Here is an update:
Download the attachement and extract the new freedb.src to %appdata%\Mp3tag\data and overwrite the old one.
Please read here if you have troubles finding the correct folder.
Note: You can also install the latest Development Build to get the update.
This post has been edited by dano: Oct 19 2006, 22:57
Go to the top of the page
+Quote Post
strixx
post Mar 23 2006, 10:10
Post #2
Member
Group: Members
Mp3tag Version: 2.35
The update did not help for me. I just replaced the file, started mp3tag but i still get no results from freedb.
Can somebody help me?
thx
+Quote Post
Florian
post Mar 23 2006, 10:14
Post #3
Developer
Group: Admin
Apparently you've copied the file to the wrong directory. Choose Start > Run... and enter
%APPDATA%\Mp3tag\data
Copy the file to this folder.
+Quote Post
strixx
post Mar 23 2006, 10:19
Post #4
Member
Group: Members
Florian: your hint helped me.
I thought the file should be copied into "program files\mp3tag\data"
because a file with the same name (freedb.src) is there.
Many thx. ;-)
+Quote Post
Florian
post Mar 23 2006, 21:09
Post #5
Developer
Group: Admin
Unfortunately there was another update on the freedb web source. Please re-download if you have troubles with the freedb web search.
+Quote Post
xxxyyz
post Mar 24 2006, 13:35
Post #6
Member
Group: Members
Mp3tag Version: 2.12
I've downloaded the latest .scr and copied it to
C:\Program Files\Mp3tag\data\ as well as to
C:\WINDOWS\Application Data\Mp3tag\data\... no joy. Is the latest script
compatible with ver 2.12? If not, is there a Win95 compatible
version of Mp3tag that would be?
Thanks, and Dano, thanks for the heads up over at the Freedb forum.
+Quote Post
Florian
post Mar 24 2006, 13:41
Post #7
Developer
Group: Admin
You can try Mp3tag v2.32a from the download page but I'm not sure, if it'll work with this version (I'm not using it anymore and support for W9x/ME/NT has been dropped).
+Quote Post
dano
post Mar 24 2006, 14:01
Post #8
Moderator
Group: Moderators
I removed the unspace command from this version since it is a rather new command.
If this also doesn't work, you can go the directory were the Mp3tag.exe is and look if there is a scripterror.log and post its content here.
Attachement removed, the problem was a different command
This post has been edited by dano: Mar 24 2006, 16:59
+Quote Post
xxxyyz
post Mar 24 2006, 15:55
Post #9
Member
Group: Members
>command.
Thanks guys! Installing ver 2.32 did the trick. The "just for me" version as
well as the latest "official" version of the script both work. Cool!
If you're curious, the error log from ver 2.12 is at
http://home.comcast.net/~xxxyyz/Mp3tag/scripterror.log . I figured
probably no one would interested, and I didn't want there to be any
misunderstanding about whether I was still having a problem or not, so
I didn't post it.
Thanks again!!
+Quote Post
extrem_oag
post Apr 6 2006, 17:53
Post #10
Member
Group: Members
somehow it still doesnt want to work for me, allthough i downloaded the new src file and copied it into the right folder. the same problem seems to extist for a friend of mine too..
has some one gut a clue whats wrong there? has there been a new update or something?
+Quote Post
Sebastian Mares
post Apr 6 2006, 18:10
Post #11
Moderator
Group: Full Members
What do you consider the right folder? It works fine for me.
There are 10 types of people in this world: those who understand binary, and those who don't.
+Quote Post
extrem_oag
post Apr 6 2006, 19:16
Post #12
Member
Group: Members
QUOTE (Sebastian Mares @ Apr 6 2006, 18:10)
as someone wrote above, i entered %APPDATA%\Mp3tag\data and copied into this folder..
+Quote Post
dano
post Jul 4 2006, 13:22
Post #13
Moderator
Group: Moderators
Again updated.
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 24th May 2013 - 19:50
