IPB
> Notice!
> Multiple Value Tags
Another Ron
post Sep 2 2006, 14:02
Post #1
Member
Group: Full Members
Mp3tag Version: 2.36a
How do I create multiple values for a tag? Can I do it without having to use the 'Extended Tags' option and entering a tag's value multiple times?
Specifically, I am tagging FLAC files and want to enter, for example, multiple artists or composers on a single track.
Thanks,
Ron
Go to the top of the page
+Quote Post
Sebastian Mares
post Sep 2 2006, 14:47
Post #2
Moderator
Group: Full Members
Mp3tag Version: 2.55a
You can separate each value by using two backslashes. Example: "Sash!\\Tina Cousins"
There are 10 types of people in this world: those who understand binary, and those who don't.
+Quote Post
Another Ron
post Sep 3 2006, 16:41
Post #3
Member
Group: Full Members
Thanks, I'll try it!
QUOTE (Sebastian Mares @ Sep 2 2006, 14:47) *
+Quote Post
Another Ron
post Sep 6 2006, 21:45
Post #4
Member
Group: Full Members
I've tried using two backslashes in the Artist tag, but when I use the flac file with SlimServer, it (SlimServer) shows one artist just as I had orginally entered it with the two backslashes.
I do not think that it is a Slim Server issue, but I am not sure. Is there a program that dumps the flac tags so I can determine if there is only one or two Artist tags?
Thanks,
Ron
+Quote Post
dano
post Sep 6 2006, 22:07
Post #5
Moderator
Group: Moderators
metaflac can show the tags.
http://flac.sourceforge.net/download.html - included in FLAC 1.1.2 for Windows (tools only)
Or try a hex editor.
+Quote Post
Another Ron
post Sep 7 2006, 21:08
Post #6
Member
Group: Full Members
I looked at a flac file with a hex editor. It appears that using two backslashes does not create two separate tags. See the attached file which is an image from the editor. I did not send the entire file because of its size. Thanks,
QUOTE (dano @ Sep 6 2006, 22:07) *
Attached thumbnail(s)
+Quote Post
dano
post Sep 7 2006, 21:23
Post #7
Moderator
Group: Moderators
You must use the tag panel, it's not supported in the columns.
Or if you want to use the columns, just press Ctrl+S after you have entered it.
This post has been edited by dano: Sep 7 2006, 21:40
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 23rd May 2013 - 15:25
