Sep 22 2006, 19:59
Post
#1
Member Group: Members Posts: 3 Joined: 22-September 06 Member No.: 3713 Mp3tag Version: 2.36a |
My first post. I am hoping to be able to add my own images to mp3's using the program. Having read a few posts here and browsed the program, I am still not sure if it is possible. Can it be done, if so how? Any help appreciated regards Derm |
Sep 22 2006, 21:21
Post
#2
![]() Moderator Group: Moderators Posts: 5500 Joined: 4-September 03 From: Germany Member No.: 201 Mp3tag Version: 2.55a |
You can press [Alt+T] or click the
Then you have the cover display on the right side. Then you can either drag a cover on it or use the -------------------- |
Sep 22 2006, 22:13
Post
#3
Hi Dano,
Thanks, I got it to work, great. ..and now I want jam on my bread Thanks again for your help. Derm |
Lo-Fi Version | Time is now: 18th May 2013 - 15:23 |
