Nov 14 2006, 19:12
Post
#1
Member Group: Full Members Posts: 1236 Joined: 25-October 05 Member No.: 2273 Mp3tag Version: - |
Is the mp3tag command-line interface documented anywhere?
Else, an anyone tell me how to fix the following command line: "C:\Program Files\Mp3tag\Mp3tag.exe" "C:\dir" so that it loads the dir? As it stands, it fails to do so if the program is already running. Thanks. |
Nov 19 2006, 18:29
Post
#2
![]() Developer Group: Admin Posts: 7621 Joined: 12-December 01 From: Germany, Dresden Member No.: 203 Mp3tag Version: 2.55a |
"C:\Program Files\Mp3tag\Mp3tag.exe" /fp:"C:\dir"
Nov 20 2006, 22:29
Post
#3
Thanks but that makes no difference.
e.g. 1 "D:\Program Files\mp3tag\mp3tag.exe" /fp:"D:\Audio\mp3\_ To Music Lib\specials" 2 Create new file in that dir 3 "D:\Program Files\mp3tag\mp3tag.exe" /fp:"D:\Audio\mp3\_ To Music Lib\specials" 4 See that mp3tag screen does not refresh - new file is not displayed. Chris This post has been edited by chrisjj: Nov 20 2006, 22:30 |
Nov 23 2006, 23:33
Post
#4
Hi Chris,
this will work with the next release! Cheers, Florian -------------------- |
Nov 23 2006, 23:47
Post
#5
Thanks. I strongly suggest that his behaviour be the /default/. I.e. that /fp be not required.
Also, it would be good for the docs to inclulde the list of switches such as /fp . This post has been edited by chrisjj: Nov 23 2006, 23:48 |
Nov 25 2006, 16:01
Post
#6
It does - thanks! Note: this improvement is missing from the change list (http://forums.mp3tag.de/index.php?s=&a...dpost&p=180) |
Lo-Fi Version | Time is now: 21st May 2013 - 13:18 |
