IPB
2 Pages V   1 2 >
> [X] 0-termination in text frames
patheticpat
post Mar 11 2007, 16:57
Post #1
Member
Group: Members
Mp3tag Version: 2.37h
I discovered the following bug in mp3tag: It appears that mp3tag writes 0-terminated strings in id3v2 text frames where according to the specs there should be no 0-termination. This problem remains mainly unnoticed, but iTunes 7.1 chokes on the extra 0x0 in UTF-8 encoded v2.4 tags.
Go to the top of the page
+Quote Post
dano
post Mar 11 2007, 17:07
Post #2
Moderator
Group: Moderators
Mp3tag Version: 2.78b
iTunes itself writes 0-termination on every frame!
And it's no problem for iTunes on other encodings, just utf-8 is a problem for it. Only Apple knows why. It's an iTunes bug!
iTunes also has more ID3v2.4 bugs that can make it problematic to use ID3v2.4 with itunes.
+Quote Post
patheticpat
post Mar 11 2007, 17:43
Post #3
Member
Group: Members
You are right, iTunes writes the 0-termination, but it doesn't write UTF-8. So, only Apple knows why it does that, but why does Mp3tag do it? I mean, it is still against the specs.
+Quote Post
Florian
post Mar 31 2007, 13:44
Post #4
Developer
Group: Admin
Mp3tag Version: 2.81
I've changed the ID3v2 writer with the current Development Build, so that frames are written without 0-termination.
It wasn't a bug, but it's probably more compatible without the 0-termination.
Kind regards,
Florian
+Quote Post
klaasklever
post Apr 1 2007, 00:38
Post #5
Member
Group: Full Members
Mp3tag Version: 2.47
So, according to the ID3 specs, is it optional or forbidden
to write terminated text strings ? I was under the impression that
it is optional (i.e. it is not against the specs to do so) ?
And besides, while increasing iTunes "compatibility", are there
any risks that this change might lead to compatibility issues on
other fronts (with other software / other devices) ?
This post has been edited by klaasklever: Apr 1 2007, 00:39
+Quote Post
Radagast
post Apr 3 2007, 13:18
Post #6
Member
Group: Members
Hello.
According to the specs of Ver. 2.4 there has to be such a termination.
QUOTE
Frames that allow different types of text encoding contains a text
encoding description byte. Possible encodings:
$00 ISO-8859-1 [ISO-8859-1]. Terminated with $00.
$01 UTF-16 [UTF-16] encoded Unicode [UNICODE] with BOM. All
strings in the same frame SHALL have the same byteorder.
Terminated with $00 00.
$02 UTF-16BE [UTF-16] encoded Unicode [UNICODE] without BOM.
$03 UTF-8 [UTF-8] encoded Unicode [UNICODE]. Terminated with $00.
Strings dependent on encoding are represented in frame descriptions
as <text string according to encoding>, or <full text string
according to encoding> if newlines are allowed. Any empty strings of
type $01 which are NULL-terminated may have the Unicode BOM followed
by a Unicode NULL ($FF FE 00 00 or $FE FF 00 00).
See also http://www.id3.org/id3v2.4.0-structure .
Regards,
Radagast
This post has been edited by Radagast: Apr 3 2007, 13:19
+Quote Post
patheticpat
post Apr 3 2007, 13:36
Post #7
Member
Group: Members
QUOTE (Radagast @ Apr 3 2007, 14:18) *
Hello.
Regards,
Radagast
Well, the specs isn't very clear regarding the termination. The termination sequences for the different character encodings are relevant for all frames holding several strings, they are separated by the termination sequences (noted as <text string according to encoding> $00 (00) in the specs). But I really don't see any point in terminating single strings. So, I don't know... tongue.gif
+Quote Post
klaasklever
post Apr 5 2007, 01:21
Post #8
Member
Group: Full Members
Well, I am confused too. From my reading it seems optional, but
the way the spec is written indicates that termination might be the preferred way.
If it is not clear from the specification, I think Mp3tag should do what is common practice
and what most other tag writers do and have done for years. If, for example Winamp, Foobar,
Windows Media Player, and Taglib (Linux) all use termination (I don't know if they do) that
would be what I mean by "common practice".
I think it would not be a good Idea to change the behavior (from termination to no termination)
more or less just because of a bug in iTunes, when it is (I don't know if it is) common practice
to terminate strings. Maybe this would cause problems with some other programs, who knows ?
Anyway, I'm not enough into the specifications and intricacies of ID3v2 to know what's best,
but I just wanted to provide some "food for thought" that maybe it could be not a good idea to
change something that fundamental just because of iTunes...
+Quote Post
dano
post Apr 5 2007, 10:40
Post #9
Moderator
Group: Moderators
To me it's pretty clear that this additional termination is wrong, but is also does not do much harm.
The big majority of programs use no termination.
The ID3v2 reference library id3lib doesn't do it.
When you read also the frame definitions of the ID3v2 standard http://www.id3.org/id3v2.4.0-frames and not only the chapter that Radagast showed, you should understand that this chapter only shows how you have to terminate a string but not when.
Compare for example chapter 4.2 with 4.2.6 from id3v2.4.0-frames
+Quote Post
Florian
post Apr 5 2007, 19:48
Post #10
Developer
Group: Admin
In addition to that, ID3v2.4 uses the terminating 0 to separate multiple strings in one frame. So a terminating 0 after the last string in a text frame could be interpreted as an additional string with zero length. Sounds a little bit hypothetical, but it could be interpreted like that.
Kind regards,
Florian
+Quote Post
Prodoc
post May 1 2007, 11:31
Post #11
Member
Group: Members
Mp3tag Version: 2.37a
Personally I think the section Radagast referred to is clear enough.
QUOTE
However, since some still find this disputable, would it be an idea to have the option to enable 0 terminating? Right now I'm tempted to stick to the latest beta which still had 0 termination but this would leave me with possible bugs and the lack of new features like TAK support.
+Quote Post
Florian
post May 1 2007, 11:35
Post #12
Developer
Group: Admin
No, this section only refers to strings which need to be terminated (which are referenced as 'terminated string' in the ID3v2.4 spec).
Can you point me to the application which requires the terminating 0 after each string?
Kind regards,
Florian
+Quote Post
jesus2099
post May 11 2007, 19:30
Post #13
Member
Group: Full Members
Mp3tag Version: 2.38
Hello !!
I have a problem since version 2.38.
My walkman now cuts the last character of my song titles and artist names ! sad.gif
I had a look in the release notes and saw this probable cause :
CODE
[2007-04-29]  REL: VERSION 2.38 (for Windows 2000/XP/2003/Vista)
[2007-03-17]  CHG: ID3v2 text frames are written without terminating 0 now.
Then I found this thread, hopefully !
Previously, my walkman (A-Data MF1), was cutting the last characters of ID3v2.4 (UTF-8) tags only.
When I used ID3v2.3 (UTF-16) tags, it was OK and displayed the full field contents.
Since mp3tag v2.38, the last character is cut, whatever the ID3v2 version…
It would be nice (at least for me) that I would be able to put this "0" back at the end of fields rolleyes.gif
Tristan
This post has been edited by jesus2099: May 11 2007, 19:55
+Quote Post
jesus2099
post Jun 9 2007, 16:13
Post #14
Member
Group: Full Members
…so it's a dead end?
+Quote Post
Florian
post Jun 9 2007, 21:13
Post #15
Developer
Group: Admin
Yes, I won't change the behaviour again and I don't think that it's good to add options for all this weird software and hardware out there.
Sorry for that!
Kind regards,
Florian
+Quote Post
2 Pages V   1 2 >
0 Members:
RSS Lo-Fi Version Time is now: 21st February 2017 - 06:45
