IPB
> Notice!
> Default mp3 Player, How Can I Set It?
Iggy64
post Aug 23 2007, 22:44
Post #1
Member
Group: Full Members
Mp3tag Version: 2.37a
My normal default mp3 player is MediaMonkey. When I view my files in Windows Explorer, the MediaMonkey icon appears next to each file. If I click on the file in Windows Explorer, the file plays in MediaMonkey.
In Mp3tag, however, when I double click a track to play it, it opens in iTunes (which is a pain for me, since it takes iTunes about 2 minutes to open). Is there a way to change/set what Mp3tag sees as the default player?
(I would remove iTunes from my computer, but I need it every once in a while for firmware upgrades on my iPod. I guess I could just rename it until I need to use it.)
Go to the top of the page
+Quote Post
Sebastian Mares
post Aug 23 2007, 23:14
Post #2
Moderator
Group: Full Members
Mp3tag Version: 2.73
http://help.mp3tag.de/en/options_tools.html
QUOTE
Default tool
If you want Mp3tag to start a special program at double clicks, you can select one of the tools from the dropdown list.
There are 10 types of people in this world: those who understand binary, and those who don't.
+Quote Post
Iggy64
post Aug 31 2007, 21:13
Post #3
Member
Group: Full Members
Your link takes me to a page showing
"Configuration > Tools"
and tells me how to set up an action on double click.
Can you please tell me how to find "Configuration > Tools"?
I have looked all throughout the menus and cannot find it.
+Quote Post
Florian
post Sep 1 2007, 01:15
Post #4
Developer
Group: Admin
Mp3tag Version: 2.81c
It's at the Options dialog.
+Quote Post
Iggy64
post Sep 1 2007, 17:10
Post #5
Member
Group: Full Members
OK, thank you.
Under Options > Tools, I created a tool called Launch Player, pointed it at MediaMonkey.exe, and checked the box to launch this tool on double clicks.
Now, when I double click on a track, it opens an instance of MediaMonkey, but it does not play the track. If I now double click on another track, it opens a second instance of MediaMonkey, but does not play a track, either.
What I need is a way to play a track in MediaMonkey (my default player) when I double click it. I can't figure out how to make this happen.
I have removed iTunes from my drive, because Mp3tag would open tracks in iTunes when I double clicked, even though MediaMonkey is set up as my default player. (And iTunes takes forever to open, and it is a resource hog.) After I removed iTunes, double clicking a track simply returned a message "Cannot open the file ...... for playing." So then I tried creating the tool to launch MediaMonkey, but I obviously did not know how to tell the tool to actually play the track, and to not launch a new instance of MediaMonkey on each double click.
Still trying to figure out how to double click a track and have it play in MediaMonkey (or anything other than iTunes).
+Quote Post
Mizery_Made
post Sep 1 2007, 19:13
Post #6
Member
Group: Full Members
Mp3tag Version: 2.57
To solve the problem of multiple MediaMonkey's opening, check the option of "Allow just one instance of MediaMonkey" in the options (of MediaMonkey). Now, for you to get it to play, need to do a tad more then just point it to MediaMonkey's EXE, for the "Parameter" put in:
CODE
/PLAY "%_path%"
This will clear your current Playlist in MediaMonkey and play the file you use this for (or add the multiple tracks and play one if you have several tracks selected.)
If you don't want your current Now Playing list cleared, you could use:
CODE
/ADD "%_path%"
That will add the track to the end of your current playing list. (but not play it automatically)
This post has been edited by Mizery_Made: Sep 1 2007, 19:14
+Quote Post
Iggy64
post Sep 1 2007, 20:55
Post #7
Member
Group: Full Members
Many, many thanks, Mizery_Made
I figured I needed to supply a parameter/argument, but I didn't know the syntax. I took some guesses, but didn't get it right. Your instructions were right on the money.
I'm somewhat new to digital audio, and am learning several new programs at the same time. While I search the forums before asking my newbie questions, I sometimes can't find the right search terms to find the answers I need.
Thanks for taking the time to answer my question.
+Quote Post
MichaelZulu
post Oct 3 2014, 14:29
Post #8
Member
Group: Full Members
Mp3tag Version: v2.53
As an Itunes user - I have to weigh in a big thank you too for posting these parameters. THANKS!
If there web page that lists some of these useful action parameters please pass on.
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 24th April 2017 - 04:25
