Jan 19 2008, 13:50
Post
#1
Member Group: Full Members Posts: 6 Joined: 8-October 05 Member No.: 2215 Mp3tag Version: 2.39 |
I have a bunch of mp3s with empty YEAR tag, but each of the singles is contained in "Artist - Year - Title" folder. How do I extract the year from it into the YEAR tag? By the way, I tried Actions, particularly Replace with regular expression. I matched the empty field and used scripting function in "replace with": CODE $regexp(%_directory%,.+\s-\s(\d+)\s-\s.+,$1) But it seems not to recognize "%_directory%" as a placeholder for parent directory (YEAR = "%_directory%"). I couldn't find a list of placeholders to be used in scripting functions and took this one from Columns. M-m, was that wrong? |
Jan 19 2008, 15:04
Post
#2
![]() Moderator Group: Moderators Posts: 5524 Joined: 4-September 03 From: Germany Member No.: 201 Mp3tag Version: 2.55a |
You are probably using the Replace with regular expression action in a wrong way and you should use a different action type.
You can try Format value Field: YEAR Format string: $regexp(%_directory%,.+\s-\s(\d+)\s-\s.+,$1) or Import value Guessing pattern: %_directory% Format string: %dummy% - %year% - %dummy% -------------------- |
Jan 20 2008, 11:23
Post
#3
I used the first suggestion and it worked. Thanks!
Lo-Fi Version | Time is now: 19th June 2013 - 18:06 |
