IPB
> Magic sort order of DOS DIR command
DetlevD
post Mar 14 2008, 09:24
Post #1
Member
Group: Full Members
Mp3tag Version: 2.54
This is output from Mp3tag Cover Export.
Yesterday I got following situation, see sort order of files, incorrect output on option /o-dne.
CODE
O:\TEST\COVERS>dir 1*.* /odne
13.03.2008  20:34             5.286 1.jpg
13.03.2008  20:34             7.813 1(1).jpg
13.03.2008  20:34             3.475 1(2).jpg
               3 Datei(en)         16.574 Bytes
O:\TEST\COVERS>dir 1*.* /o-dne
Today, with newly created files, I got following situation, see sort order of files, correct output on option /o-dne.
CODE
14.03.2008  09:16             5.286 1.jpg
14.03.2008  09:16             7.813 1(1).jpg
14.03.2008  09:16             3.475 1(2).jpg
So what the heck is going on there?
DD.20080314.0924.CET
This post has been edited by DetlevD: Mar 14 2008, 19:39
Go to the top of the page
+Quote Post
LyricsLover
post Mar 14 2008, 17:34
Post #2
Member
Group: Full Members
You could check the entire D (Date/Time). In my german DOS, the help shows the following explanation:
QUOTE ("german DOS")
D Datum/Zeit (ältere zuerst)
I think your files have some additional (but not visible) information in the time: The seconds.
Maybe this seconds make the difference in sort order?
+Quote Post
DetlevD
post Mar 15 2008, 17:18
Post #3
Member
Group: Full Members
QUOTE (LyricsLover @ Mar 14 2008, 17:34) *
You could check the entire D (Date/Time). ...
This is what I did, see option /o-dne, that means sort by date in reverse order.
Could it be that the filesystem registers two files at the identical time point, when they were created in sequence one after another by Mp3tag cover export?
DD.20080315.1717.CET
I checked it again and see what happened:
CODE
O:\TEST\COVERS>dir *.* /od
15.03.2008  18:08             3.475 1(2).jpg
15.03.2008  18:08             7.813 1(1).jpg
15.03.2008  18:08             5.286 1.jpg
15.03.2008  18:08                22 identify.in.txt
15.03.2008  18:08             4.110 Mp3tag.magick.identify.cmd
15.03.2008  18:11    <DIR>          ..
Identical sort order /od using different search masks gives different sort results.
Looks like a DOS bug.
DD.20080315.1822.CET
This post has been edited by DetlevD: Mar 15 2008, 18:21
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 25th May 2013 - 06:38
